| New Reply |
Nuclear Fusion_New Method_Patent Pending |
Share Thread | Thread Tools |
| Mar30-11, 05:17 AM | #1 |
Hello All,
This is patent pending Method of Nuclear Fusion (attached file) What do you think about this? Joseph |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Mar30-11, 06:02 AM | #2 |
Sounds as impractical as other beam fusion methods as far as energy production goes. Come back when you have a working prototype. ("Patent Pending" doesn't mean anything until then.)
Getting a reaction to occur is relatively "easy". The trick is in tapping the energy of the fusion reaction to replace all of the energy used to set up the reaction. Accelerating a beam is pretty energy intensive at large particle currents. The stage where fusion occurs will randomize the relative velocities, especially the relative velocities along the direction of the two beams. These will thermalize and you'll end up with one hot beam. I understand your idea is to use the sufficient net velocity to make refocusing the beams easier. But for sustained fusion you'll be no different from a method involving focusing a single beam. You'll have the same difficulties getting the energy from the fusion out and used to maintain your beam(s). |
| Mar30-11, 07:00 AM | #3 |
"Accelerating a beam is pretty energy intensive"
Not more intensive then heating plasma by one of following ways: -Ohmic heating -Neutrals beams (here namely accelerating is used) -RF or their combination "These will thermalize and you'll end up with one hot beam." Russian physicist Budker in his "Stabilized electronic beam" article has shown that in case of enough high relativism of electronic beam (the range from 1.5 to 5 MeV is already enough) and partial compensation of space charge, this beam will radiate and consequently will cool. Also the radiation of electrons will struggle with the majority of types of instabilities. And by the Method we need not total but only partial compensation of positive space charge. So, we easily can find conditions when fusion reaction responses will exceed the energetic expenses. And I think that further utilisation of fusion energy will be easier too. |
| Mar30-11, 12:57 PM | #4 |
Nuclear Fusion_New Method_Patent Pendingyes, but these methods w.r.t. tokomak's et al, were a.) methods to heat the plasma, and b.) methods to initially heat the plasma which are supposed to be unnecessary once the fusion reaction produces enough heat to maintain the necessary temperature, and c.) methods used with another as yet unsuccessful method of generating sustained fusion power, oh yes, and d.) for the beams, are a matter of accelerating a substantially smaller particle current than your entire set of fusion reactants. If the goal is to use energy to heat the plasma, then the fusion reaction will already handle that, no need to tap and convert. The main problem actually is to keep the plasma from cooling too fast to sustain the reaction. As far as your method is concerned, you need to tap fusion energy, convert it to coherent energy in the form of e.g. electrical power and RF waves to contain and accelerate the beams. This must be done in your method continuously and not just as a start-up procedure. It is a question of how much Helmholtz free energy you tap from the fusion, not just thermal energy. This I doubt. Remember, to get high fusion rates you will get higher 90deg scattering rates. Whatever your relative speed of your two component beams, these will be lost on the first pass. There will be no recycling of particles to collide again except as an essentially single beam method. I've thought about this myself over many a beer, something like a fusion ram-jet, pinch to heat to fusion, expand and cool and accelerate, tap the flow energy via MHD, recycle. It might even work on a large enough scale. But I think Bussard's Polywell is more likely to succeed. |
| Mar30-11, 01:49 PM | #5 |
Yes, but also we should remember that when we talk about Tokamak and other projects anywhere only partial burning-off of fuel is meant. I propose near 100% burning-off. As far as your method is concerned, you need to tap fusion energy, convert it to coherent energy in the form of e.g. electrical power and RF waves to contain and accelerate the beams. Actually the efficiency of accelerators is high enough. This must be done in your method continuously and not just as a start-up procedure. Yes All well and good for maintaining a stable plasma, cooling is desired in maintaining a beam, it is the energy costs I'm skeptical of and so of the following It should be investigated. But tapping of reactions directly depends on ions current, current of electrons which we need is about tenth of ion's current. Also radiation and stability will highly dependent on relativistic factor. Remember, to get high fusion rates you will get higher 90deg scattering rates. Mainly not 90deg but a lot of scattering on small angles. But electronic beam will return reacting particles to the axel. Scattering will produce the radial motion increasing the temperature and radiation will disipate this thermal energy then. In fact we will have friction between the proposed three beams. And for solving of this problem there is proposed the following: For compensation of alignment of speeds (velocities) of particles beams of reacting components and also for compensation of energy losses (radiant losses) of focusing electrons it is offered to create the longitudinal electric field. Thank you for discussion and sorry for bad English. |
| Mar30-11, 09:49 PM | #6 |
This sounds similar to a Polywell, where they trap a well of electrons in the center of a device and inject positive ions, which are accelerated by the electron well and oscillate back and forth through the center of the device until they fuse. One of the main problems they had was that they kept losing electrons from the well. I don't see how your device will produce excess energy if all those electrons from the beams are simply lost or have their energy radiated away.
| Mar30-11, 10:56 PM | #7 |
I do not see similarity because I propose to use three independly created beams and then to direct them along the common axel - not "positive ions, which are accelerated by the electron well" but each beam is accelerated by its own accelerator - positive ions and electrons. I propose to use the electron beam for only partial compensation of ion's positive space charge. Remaining space charge will be compensated by the magnetical attraction of all three beams. So, we need much less concentration in electron beam in comparison of ions. And we should spend initially for acceleration of each elementary fusion act tens or hundreds of keVs and waiting MeVs. I do not see for electrons the possibility of their losing. Radiation - yes. The radiation caused with as I already meintained "friction" between three beams. But friction and energy dissipation (radiation in our case) we have in any energetic settings - e.g. in internal combustion engine. But they work with some positive efficiency! |
| Mar30-11, 11:48 PM | #8 |
I apologize, I misread your document and thought the beams were all electron beams.
How will you recycle the the power lost from the ions that dont fuse and the electrons that simply pass through? I think those two factors will contribute to significant energy loss unless they can be recycled. Also, the radiation losses, while mostly recoverable, still represent losses that have to be accounted for. All in all I think it is an interesting design. Have you done anything with this yet? Built anything yet? |
| Mar31-11, 12:37 AM | #9 |
How will you recycle the power lost from the ions that dont fuse and the electrons that simply pass through? I think those two factors will contribute to significant energy loss unless they can be recycled.
I have two ideas (designs) for realization the Method.
And in linear design the reaction length should be big enough for near 100% burning-off of fuel. Longitudinal electric field will compensate the alignment of ions relative speeds especially if we would use different kinds of ions in defferent beams. For example if we use deuterium and tritium beams with faster deuteriums particles the alignment will be compensated by the higher rate of acceleration of lighter particles. But certainly I like an idea to use aneutronic reactions: e.g. De+He3 And for recycling the power we can use e.g. MHD principle. Also, the radiation losses, while mostly recoverable, still represent losses that have to be accounted for. I like the phrase "mostly recoverable" but unfortunately with limited efficiency. Have you done anything with this yet? Built anything yet? No I have not. I am individual and can not build this. I wait that cost of construction of experimental set will reach tens millions USD. Very costly for me and for any other individual as well. |
| Mar31-11, 12:44 AM | #10 |
Could you not build a small scale working model to prove your design? Even if it wouldn't produce net power.
| Mar31-11, 01:12 AM | #11 |
I wait some trigger level of current of electronic beam.
And for example Budker Institute of Nuclear Physics sells for commercial application electron accelerator with beam power of 100 kWt at about 7 millions USD http://www.inp.nsk.su/products/indaccel/Pres_ILU14.pdf Interesting that power consumption they declare is 500 kWt. So, 20% of efficiency. |
| Mar31-11, 02:25 AM | #12 |
that word document is no patent should there be merit - I cannot judge - you now have forfeited a patent as your idea is in the public domain and no longer patentable. |
| Mar31-11, 03:09 AM | #13 |
Thank you, I understand. I am not lawyer but in general am familiar with patent legislation.
Here I published the main idea of invention. And your answer is like that if I will say that married and have two sons you will ask me marriage certificate and birth certificates. My publication here was caused only with my interest to hear the judgement of physicists and not lawyers. |
| Apr12-11, 09:20 AM | #14 |
| Apr12-11, 03:56 PM | #15 |
| Apr12-11, 07:15 PM | #16 |
| Apr12-11, 09:54 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Nuclear Fusion_New Method_Patent Pending
| Attachments Pending Approval | Forum Feedback & Announcements | 4 | ||
