New Reply
Calculating coefficient of static friction without a mass.
Share Thread
Mar30-11, 05:54 AM   #1
A car is travelling at 30m/s around a bend of radius 70m. What coefficient of static friction between the tires and the road is required to ensure the car will not slip?
2. Relevant equations
3. The attempt at a solution
I know that the centripetal acceleration is a=30^2/70
and I know that this acceleration has to be canceled out by the frictional force for the car to not slip, but I am not sure out to calculate frictional force F=mA without a mass for the car.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar30-11, 06:15 AM   #2
Mentor
Quote by Gheret View Post
Maybe you don't need the actual mass. Try calling the mass 'm' and see what happens.
(Tip: Solve things symbolically as much as possible. Only use the calculator at the end.)
Mar30-11, 07:16 AM   #3
Quote by Doc Al View Post
I'm guessing that since mass will not change and the two forces have to be equal the m will cancel out but I still do not know how to calculate the acceleration into newtons for this situation.
Mar30-11, 07:29 AM   #4
Mentor
You're right. But no need to guess: Try it and see!
I assume that you mean you cannot calculate the force in Newtons. True, without the mass, you cannot calculate the force. So what? You can figure out the coefficient of friction, which is all you need.
Mar30-11, 07:38 AM   #5
I'm sorry but I am totally lost now..
What I have done so far: F(r)=mv^2/r=F(fr)
F(r) being centripetal force and F(fr) being frictional force.
But I do not know the equation for calculating coefficient of static friction.
Thanks for helping me out.
Mar30-11, 07:44 AM   #6
Mentor
How does the maximum static friction force relate to the normal force between surfaces?
Mar30-11, 07:47 AM   #7
Oh I was completely ignoring normal force!
F=u(9.8m/s^-2)m
mv^2/r=u(9.8m/s^-2)m
(30)^2/70=u(9.8)
Right?
Mar30-11, 07:49 AM   #8
Mentor
Right!
(This assumes that the road is flat--no banking angle.)
Mar30-11, 07:51 AM   #9
You have been the best help.
Thank you for not just telling me the answer cause now I have actually learnt how to solve these for myself.
Thank you!
New Reply
Tags
curves, force, friction, without mass
Similar discussions for: Calculating coefficient of static friction without a mass.
Thread Forum Replies
How to find the maximum acceleration given coefficient of static friction and mass Introductory Physics Homework 6
Calculating the Coefficient of Static Friction Introductory Physics Homework 2
Friction problem with banked curve given static friction coefficient Introductory Physics Homework 3
Calculating coefficient of max static friction Classical Physics 2
finding mass and acceleration? (deals with coefficient of static friction) Introductory Physics Homework 0
