Why Does the Spaceship Come to a Halt When Firing a Rocket?
The discussion centers on the physics of a spaceship coming to a halt when firing a rocket. The spaceship, initially traveling at +250 m/s, has a mass of 2.0 x 106 kg, while the rocket weighs 1200 kg. The correct approach to determine the rocket's velocity involves applying the conservation of momentum, rather than using the center of mass velocity equation. The momentum before firing is equal to the momentum after firing, allowing for the calculation of the rocket's velocity.
  • Understanding of conservation of momentum in physics
  • Familiarity with basic kinematic equations
  • Knowledge of mass and velocity relationships
  • Ability to perform calculations involving large numbers and scientific notation
  • Study the principles of conservation of momentum in closed systems
  • Learn how to apply kinematic equations to real-world scenarios
  • Explore the concept of center of mass and its implications in physics
  • Practice problems involving momentum transfer in collisions and propulsion
Physics students, educators, and anyone interested in understanding the mechanics of motion and momentum in space travel.
shawonna23
With the engines off, a spaceship is coasting at a velocity of +250 m/s through outer space. The ship carries rockets that are mounted in firing tubes, the back ends of which are closed. It fires a rocket straight ahead at an enemy vessel. The mass of the rocket is 1200 kg, and the mass of the spaceship (not including the rocket) is 2.0 106 kg. The firing of the rocket brings the spaceship to a halt. What is the velocity of the rocket?
I used the equation vcm=(m1*v1+m2*v2)/(m1+m2) but the answer I got is wrong. Please help ASAP!
The idea is that whole of the momentum of the ship is transferred to the rocket.
Just use the conservation of momentum. The momentum which was shared by both the rocket and ship before is now with the rocket alone.
This will tell you the rocket's velocity.
spacetime
www.geocities.com/physics_all
This formula calculates the velocity of the center of mass (CM) of the system. That velocity does not change. If you wanted to apply this to the problem, you'd calculate the velocity of the CM before and after, and set them equal. Do it and you'll see that is equivalent to applying conservation of momentum.
Please do not double post!
11K
34K
