Do magnets attract magnetic objects of different mass with equal force?
The discussion clarifies that magnets do not attract magnetic objects of different masses with varying forces when placed at the same distance. The magnetic force is independent of the mass of the objects involved, contrary to gravitational force, which varies with mass. The participants emphasized that the magnetic force can be approximated by considering the interaction of magnetic dipoles, but this simplification neglects the influence of neighboring magnets. Thus, the formula for magnetic forces remains constant regardless of the mass of the magnetic objects.
  • Understanding of magnetic dipoles and their interactions
  • Basic knowledge of magnetic force principles
  • Familiarity with gravitational force equations
  • Concept of distance in force calculations
  • Research the principles of magnetic dipole interactions
  • Study the mathematical formulation of magnetic forces
  • Explore the differences between magnetic and gravitational forces
  • Investigate the effects of neighboring magnets on magnetic force
Students of physics, educators teaching magnetism, and anyone interested in the fundamental principles of magnetic forces and their applications.
jonnyk
Hi,
Doesn't a magnet attract objects of different mass(consider Point mass), but placed at the same distance from it and of the same magnetic substance, with different forces, similar as is the case with gravitational force with Force=G*mass1*mass2/distance between them^2 ?
For example if an "a" mg iron filing is placed "x" cm from a magnet, will the magnet produce the same or a different force on it as it would on a filing with "b" mg, also placed "x" cm from the magnet?
If different what is the formula for magnetic forces between varying masses?
Thanks.
Permanent magnets you mean? Yeah you can sort of think of a "magnet" as a collection of smaller magnetic dipoles and then superpose them, except you must consider that neighboring magnets influence each dipole. But neglecting this will give you a crude approximation.
The magnetic force does not depend on the mass of either object.
  • · Replies 60 ·
12K
