Can a Riemannian Manifold Allow the Existence of a Square Circle?
The discussion revolves around the theoretical possibility of defining a Riemannian manifold that allows for the existence of a "square circle," a concept often used in philosophical contexts to illustrate impossibility. Participants explore the implications of definitions and geometrical frameworks, particularly focusing on Riemannian metrics and their properties.
  • Some participants propose that the impossibility of a square circle depends on the definitions of "square" and "circle" and the geometry being used.
  • It is noted that in Euclidean 2-space, a square circle cannot exist under widely accepted definitions.
  • One participant suggests that a Riemannian manifold might allow for the existence of a square circle if suitably defined, questioning the need for differentiability at certain points.
  • Another participant argues that while a metric can be defined in Euclidean space where the unit circle is a square, on a Riemannian manifold, the set of points equidistant from a central point must form a smooth closed curve.
  • Concerns are raised regarding the smoothness of the square, with acknowledgment that its tangent is discontinuous at vertices, which complicates its classification as a smooth curve.
  • A question is posed about whether smoothness can be proven as a necessary consequence of the definition of a circle, particularly in the context of making a square circle impossible.
  • It is mentioned that in a non-Riemannian metric, the set of points equidistant from a point does not have to be a circle, contrasting with the requirements on a Riemannian manifold.
Participants express differing views on the definitions and properties of circles and squares in the context of Riemannian manifolds. There is no consensus on whether a square circle can exist or the implications of smoothness on this possibility.
Limitations include the dependence on definitions of geometric terms and the unresolved nature of the smoothness requirement for circles in relation to the existence of a square circle.
andrewkirk
Insights Author
In certain philosophy discussions the concept of a square circle sometimes comes up as an example of something that can be proven not to exist.
It occurred to me that the impossibility of its existence depends on:
1. the definitions one uses for square and circle; and
2. the geometry in which one is working.
It is well known that, given any widely accepted definition of the two terms, a square circle cannot exist in Euclidean 2-space. However I wondered whether it might be possible for one to exist on a suitably defined Riemannian manifold.
Say we take the following definitions, which match my intuitive concept of a circle and a square:
- A circle of radius r centred on a point P in the plane is the set of all points whose distance from P (measured along a geodesic) is r.
- A square of side L is a set of points comprising the union of four geodesic segments, each of length L, with each end point of each segment being common with the end point of one other segment, no intersections of segments other than on the ends, and the tangent vectors to any two intersecting line segments are orthogonal at the point of intersection.
Is it possible to define a Riemannian metric for a two-dimensional manifold that would allow one or more sets to satisfy both definitions?
Would we have to lose differentiability at some points?
You can define a metric - not Riemannian - on Euclidean space whose unit circle is a square
On a Riemannian manifold the set of point equidistant from a central point - if the distance is small enough - is a smooth closed curve. It is a circle by definition on a manifold but may not be a circle when the manifold is embedded in Euclidean space.
your definition of a square can not be a smooth curve.
Thank you for your reply.
I agree the square will not be a smooth curve, because the tangent is discontinuous at the vertices.
However smoothness is not part of the above definition of a circle. Is it possible to prove that smoothness is a consequence of the definition, bearing in mind that for smoothness to make a square circle impossible, we would need to show that all circles must be smooth, not just some (eg small ones)?
In a non-Riemannian metric the set of point equidistant from a point does not have to be a circle.
however on a Riemannian manifold it must be a smooth curve.
  • · Replies 16 ·
  • · Replies 27 ·
