New Reply
Cayley Hamilton Theorem
Share Thread Thread Tools
Apr1-11, 09:49 AM   #1
Are there any nice applications of the Cayley Hamilton Theorem. I am looking for a real life application which would motivate students.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr1-11, 04:25 PM   #2
Recognitions:
Homework Helper Homework Help
There are many, i depends on what you mean by "real life application".
1)Ordinary differential equations
suppose we have some vector space of functions closed under differentiation
ie x'=Ax
if p is the characteristic polynomial
p(A)x=p(D)x=0
so we can solve for x
2)basis for F[A] (all operator polynomials)
clearly dim(F[A])<=n^2
but the Cayley Hamilton Theorem gives an improvement to
dim(F[A])<=n
thus we can reduce operator polynomials (though not in the best way possible in general)
invert nonsingular operators
reduce some infinite series to finite series
like exp(At)~I+A+(1/2)A^2+...+(1/n!)A^n+...
which we can also use to solve Ordinary differential equations
Apr25-11, 03:22 AM   #3
Hey matqkks,
I have come across the Cayley-Hamilton theorem in a college rheology class. Rheology is basically the study of material behaviour, and so rheologists look for equations that can describe materials.
Elastic solids are simple in this regard, and can be with a linear relationship between stress state (described by the stress tensor [tex]\mathbf{T}[/tex]) and deformation state (described by the deformation tensor [tex]\mathbf{B}[/tex]):
[tex] \mathbf{T} = c\mathbf{B}[/tex]
Some materials behave non-linearly, so you can try describing them by taking a power series in stead of just a constant function
[tex]\mathbf{T} = f_0\mathbf{B}^0 + f_1\mathbf{B} + f_2\mathbf{B}^2 + f_3\mathbf{B}^3 + ...[/tex]
Using the Cayley-Hamilton theorem, we can express all the higher power tensors in terms of the lower power tensors and the invariants of [tex]\mathbf{B}[/tex]. With some elimination you can end up with the expression:
[tex]\mathbf{T} = g_0\mathbf{I} + g_1\mathbf{B} + g_2\mathbf{B}^{-1}[/tex]
Some further analysis shows that [tex]g_0 = -p[/tex] (pressure) and [tex]g_1[/tex] and [tex]g_2[/tex] are functions of the first and second invariant of [tex]\mathbf{B}[/tex].
This has now allowed rheologists to express complex material behaviour in terms of just the deformation state tensor and its invariant.
A similar analysis can be employed for describing viscous fluid behaviour. The only big difference is that not the deformation state tensor, but the rate of deformation tensor is used in the power expansion.
[tex]\mathbf{T} = -p\mathbf{I} + \eta_1\mathbf{2D} + \eta_2(\mathbf{2D})^2[/tex]
With [tex]eta_1[/tex] and [tex]eta_2[/tex] a function of the second and third invariants of [tex]\mathbf{2D}[/tex].
However, it tuned out that this equation gave the wrong predictions. The error arose with the last term, so it was dropped and the general equation describing viscous fluids:
[tex]\mathbf{T} = -p\mathbf{I} + \eta_1\mathbf{2D}[/tex]
Hopefully this has given you some idea of the application of the Cayley-Hamiltonian theorem. :-)
Jun22-12, 02:08 AM   #4
In linear algebra, the Cayley–Hamilton theorem (named after the mathematicians Arthur Cayley and William Hamilton) states that every square matrix over a commutative ring (such as the real or complex field) satisfies its own characteristic equation.
An application
Take a square matrix A of order n and a polynomial T(x) of degree r, such that r>n. How can we compute T(A)?
Of course a direct computation is always possible, but perhaps not so illuminating.
Denote by PA(x) the characteristic polynomial of A and then use Euclide's algorithm: there exists a unique ordered pair of polynomials (Q(x),R(x)) such that T(x)=Q(x) PA(x) +R(x) and .
By Cayley-Hamilton's Theorem , we have:
T(A) = R (A)
New Reply
Tags
cayley hamilton, linear alegbra
Thread Tools
Similar Threads for: Cayley Hamilton Theorem
Thread Forum Replies
Cayley-Hamilton theorem for Operator Differential Equations 1
Cayley's theorem Linear & Abstract Algebra 1
Prooving the Cayley-Hamilton Theorem Linear & Abstract Algebra 0
cayley hamilton Linear & Abstract Algebra 7
cayley - hamilton theorem Linear & Abstract Algebra 7
