Definition of Differentiablility/Continuity f:R^2->R
  • Context: Graduate
  • Thread starter Thread starter clearweave
    Definition
The discussion centers on the differentiability and continuity of the function defined as f:R^2-->R, where f(0,0)=0 and f(x,y)=x^3/(x^2+y^2). The partial derivatives at (0,0) exist and are 1 and 0, respectively. However, the function is not continuous at (0,0) due to the limit yielding an indeterminate form of 0/0. Consequently, since differentiability implies continuity, the function is also not differentiable at (0,0). The correct approach to proving continuity involves estimating limits and establishing a delta-epsilon relationship.
  • Understanding of partial derivatives and their existence
  • Knowledge of continuity and differentiability definitions in multivariable calculus
  • Familiarity with limit evaluation techniques, including epsilon-delta proofs
  • Proficiency in using norms such as the Euclidean norm in analysis
  • Study the epsilon-delta definition of continuity in multivariable functions
  • Learn about the implications of partial derivatives on differentiability
  • Explore limit evaluation techniques for indeterminate forms
  • Investigate the use of norms in proving continuity and differentiability
Students and educators in advanced calculus, mathematicians focusing on multivariable analysis, and anyone seeking to deepen their understanding of differentiability and continuity in mathematical functions.
clearweave
Definition of Differentiablility/Continuity f:R^2-->R
Good afternoon,
On a test I was given the question:
Define f:R^2-->R by f(0,0)=0 and f(x,y)=x^3/(x^2+y^2)
(1) Do the partial derivatives at x and y exist at 0? Which I answered yes to, and showed that they equal 1 and 0, respectively.
(2) Is f differentiable at 0? Justify your answer.
(3) Is f continuous at 0? Justify your answer.
For part (2) I had trouble getting anywhere by the definition of a derivative with lim (h1,h2)-->(0,0) of [f((0,0)+(h1,h2))-f(0,0)]/norm(h1,h2), so I continued to (3) the continuity problem and since lim (x1,x2)-->(0,0) of f(x1,x2)=0/0 and is thus undefined, I stated that the definition of continuity lim (x1,x2)-->(a1,a2) of f(x1,x2) = f(a1,a2) thus cannot hold, so f is not continuous at (0,0). Since differentiability implies continuity, I used the contrapositive argument for (2) referencing (3), and I did not receive any credit for problems (2) and (3).
I considered the L1 norm, the Euclidean norm, and the sup norm for (2) to no avail, so I figured that it was possible the function is not differentiable at (0,0) since existence of partial derivatives does not imply complete differentiability... But apparently that was not the case here. Could anyone please help me solve (2) and (3) successfully? Thank you!
For (3), you calculated the limit to be 0/0, this is correct, but it is not enough. when you get 0/0 (or any other indeterminate form), then the limit might still exist, but you'll need to find another method to solve the limit.
To prove continuity, we often use the following inequalities:
[tex]|x|\leq \sqrt{x^2+y^2},~\frac{x}{x+1}<1,~\frac{x^2}{x^2+y^2}<1[/tex].
Now, we need to find an delta such that
[tex]\sqrt{x^2+y^2}<\delta~\Rightarrow~\left|\frac{x^3}{x^2+y^2}\right|<\epsilon[/tex]
We make the following estimation
[tex]\left|\frac{x^3}{x^2+y^2}\right|\leq |x|\left|\frac{x^2}{x^2+y^2}\right|\leq |x|\leq \sqrt{x^2+y^2}<\delta[/tex]
So choose delta=epsilon, and the definition is satisfied. Thus the function is continuous.
For differentiability, we need to check the definition, that is, we must find a linear function u such that
[tex]\lim_{h\rightarrow 0}{\frac{f(h)-f(0)-u(h)}{\|h\|}}[/tex]
From your theory, you should know that there is only one possible choice for u(x,y), namely
[tex]u(x,y)=x\frac{\partial f}{\partial x}(0)+y\frac{\partial f}{\partial y}(0)[/tex]=x[/tex]
So, we need to check whether the limit
[tex]\lim_{(h_1,h_2)\rightarrow (0,0)}\frac{f(h_1,h_2)-f(0,0)-(h_1,h_2)}{\sqrt{h_1+h_2}}=\lim_{(h_1,h_2)\rightarrow (0,0)}\frac{h_2^3}{\sqrt{(h_1+h_2)^3}}[/tex]
However, you can check that this is not the case. Thus the function is not differentiable...
