Average force and force/tension used
This discussion centers on the relationship between force, speed, and distance in the context of lifting weights. The example of two butterflies illustrates that a higher frequency of movement (six flaps in 3 seconds) results in greater distance covered (18m) compared to a slower movement (one flap in 3 seconds covering 3m). The conclusion drawn is that more force is required to achieve faster movements, leading to increased energy expenditure and muscle tension. The participants emphasize that the total force exerted cannot be the same if the distance moved in the same time frame differs significantly.
  • Understanding of basic physics concepts such as force, speed, and distance.
  • Familiarity with weightlifting terminology, including repetition maximum (1RM).
  • Knowledge of energy expenditure in physical activities.
  • Concept of impulse and its relation to force and time.
  • Research the physics of force and motion, focusing on Newton's laws of motion.
  • Explore the concept of impulse in greater detail and its applications in strength training.
  • Learn about energy expenditure calculations during different types of physical activities.
  • Investigate the biomechanics of weightlifting and how speed affects muscle tension and performance.
Fitness enthusiasts, strength trainers, sports scientists, and anyone interested in understanding the mechanics of force application in weightlifting and its effects on muscle performance.
waynexk8
Not sure why my threads are closed ? As I think this needs an answer. To be honest, I do not think most here might have understood the question; let me explain the answer for you.
Imagine a giant Butterfly, one Butterfly flaps their wings once up for a height of 3m, taking 3 seconds, and then flaps them down for 3m, taking 3 seconds. Thus one flap. The Butterfly moves up in the air 3m.
Another Butterfly, flaps their wings once up for a height of 3m, taking .5 of second, and then flaps them down for 3m, taking .5 of a second. Thus six flaps. The Butterfly moves up in the air 18m.
A force is something that causes a object to undergo a change in speed, thus the most force for the same time frame, and the object undergoes more of a change in speed “thus covers more distance in the same time frame” right ?
So the second Butterfly produced MORE force/strength to move their wings, to move their whole bodies faster at more speed coving more distance. Butterfly one, did not produce as much force/strength in the same time frame, thus did not move so fast with as much speed, thus coved less distance.
Would you think I am right or wrong ? If wrong, how can Butterfly one not move as fast, with less speed, coving less distance if it used the same force/strength in the same time frame ? As a force is something that causes a object to undergo a change in speed, thus the most force for the same time frame, and the object undergoes more of a change in speed “thus covers more distance in the same time frame” right ?
Wayne
We all agreed that the faster reps/flaps used far far more energy in the same time frame, but NO ONE said why ? If you use more energy in moving a body part faster in the same time frame, you “must” use more power, as more physical work is done and as we said more energy, so this in turn can mean only one thing, that we used more force/strength to use more energy to move the object more distance or do more work in the same time frame.
If not, HOW can the object move faster and further in the same time frame if you don’t use more force/strength ?
Wayne
I would like another try here please, as I am not sure if the members seemed to understand my question, which is above and below. No one actualy told me how much force was used and how/why ? As we do know that in the below you fail roughly 50% faster in doing the faster reps, thus this would mean you are putting more tension on the muscles as of the more force used.
Question, which uses the more force,
A,
As I have say lifted the 80 pounds up and down 1m for 6 times in 6 seconds, I have moved the weight 12m in all, but the slower repper has only lifted their weight 2m in 6 seconds, as I have lifted the same weight 10m more in the same time frame, “how” can the slow repper have used as much total or overall force ?
B,
In .5 of a second I have moved the weight 1000mm, the slower repper on the other hand has moved the weight only 166mm, just tell me HOW you think you have used the exact same force, but only moved the weight one sixth of what I have moved it. DO NOT YOU AGREE THAT I HAVE USED MORE FORCE/STRENGTH TO DO THIS ? AND IF NOT WHY ? HOW CAN WHAT YOU THINK, THE SAME FORCE MOVE THE SAME OBJECT IN THE SAME TIME FRAME 166MM AND 1000MM ? ITS JUST IMPOSSIBLE.
C,
Impulse. When a force is applied to a weight, it changes the movement of that body. A small force applied for a long time can produce the same movement change as a large force applied briefly, because it is the product of the force and the time for which it is applied that is important. BUT BOTH THESE FORCES ARE USED FOR THE SAME TIME, the only way the slower force could catch up if it went on longer, then it would move the weight the same distance.
Problem,
I lift 80% or 80 pounds of my 1RM {repetition maximum} 1m up and 1m down 6 times in 6 seconds, they lift 80% or 80 pounds of their 1RM {repetition maximum} 1m up and 1m down 1 time in 6 seconds, who uses the most overall or total force, or who puts the most tension on the muscles in the 6 seconds
Wayne
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 51 ·
  • · Replies 41 ·
  • · Replies 21 ·
  • · Replies 35 ·
