Cantor Set: 7/12, 1/3, 1/4, 11/12
  • Thread starter Thread starter tylerc1991
    Cantor Set
The discussion focuses on identifying which fractions—7/12, 1/3, 1/4, and 11/12—belong to the Cantor set and their corresponding ternary expansions. It is established that 1/3 is in the Cantor set, represented as 0.022222... in ternary. The user expresses uncertainty about 1/4 and 11/12 but is guided to understand that numbers in the Cantor set have ternary expansions consisting solely of the digits 0 and 2. The method of long division is recommended for deriving ternary expansions systematically.
  • Understanding of the Cantor set and its properties
  • Knowledge of ternary number system and expansions
  • Familiarity with long division in base conversions
  • Basic concepts of real analysis related to intervals and endpoints
  • Learn how to derive ternary expansions using long division
  • Study the properties of the Cantor set in detail
  • Explore the implications of numbers in the Cantor set on real analysis
  • Investigate other sets with similar properties, such as the middle-thirds Cantor set
Mathematics students, educators, and anyone interested in real analysis or set theory, particularly those studying the Cantor set and its characteristics.
tylerc1991
Which of the following are in the Cantor set: 7/12, 1/3, 1/4, 11/12? Give the ternary expansion of each.
I see that 1/3 is in the Cantor set and has a ternary expansion:
1/3 = 0/3 + 2/3^2 + 2/3^3 + 2/3^4 + ...
I am fairly certain that 1/4 as well as 11/12 are in the Cantor set as well, although I am not exactly sure how to go about showing this. When deciding if 1/3 was in the Cantor set or not I noticed that the endpoints of the intervals would always stay in the set (like 0 and 1 for instance), and after removing the middle 1/3 the first time, 1/3 became an endpoint. As for 1/4 and 11/12 I am not certain and would appreciate any direction and/or intuition. Thank you!
They want you to get ternary expansions of all those numbers anyway, so why don't you do that part first. Numbers in the cantor set have ternary expansions consisting of only the digits 0 and 2. Like you have found 1/3=0.022222... You could also have written 1/3=0.1 in ternary, but that's the only sort of ambiguity. To systematically get ternary expansion use 'long division'. If you remember how to do it in base 10 you just have to make a few adjustments.
