Calculating Potential Energy for 16 kg Object
The potential energy of a 16 kg object acted upon by the conservative force F = (-2.9)x + (-4.8)x² at x = 2.0 m is calculated to be 18.6 J. To determine the object's speed as it passes through the origin (x = 0), the conservation of energy principle is applied. The total energy at x = 5.0 m, where the object has a velocity of 5.0 m/s, is 200 J. Consequently, the speed of the object when it reaches the origin is confirmed to be 5 m/s.
  • Understanding of conservative forces and potential energy
  • Knowledge of kinetic energy calculations
  • Familiarity with the work-energy principle
  • Ability to perform integration for potential energy calculations
  • Study the work-energy theorem in classical mechanics
  • Learn about conservative forces and their implications on energy
  • Explore integration techniques for calculating potential energy
  • Investigate the relationship between kinetic and potential energy in dynamic systems
Students in physics, educators teaching mechanics, and anyone interested in understanding energy conservation in physical systems.
strugglin-physics
A 16 kg object is acted on by a conservative force given by F = (-2.9)x + (-4.8)x2, with F in Newtons and x in meters. Take the potential energy associated with the force to be zero when the object is at x = 0. What is the potential energy of the system associated with the force when the object is at x = 2.0 m?
I found this answer to be 18.6 J
But I can't get the second half of the question...
If the object has a velocity of 5.0 m/s in the negative direction of the x-axis when it is at x = 5.0 m, what is its speed when it passes through the origin?
I thought I could do it using the formulas for constant acceleration but I don't know the acceleration or the time. Any suggestion for what formula to use?
Use the princlipple of conservation of energy. You have potential energies for both locations and a kinetic energy ao one location. The problem states the force acting on the particle is conservative so POCOE is fairly easy to implement here. Just realize that the sum of the potential and kinetic energy at 5m equals the sum of the energys at 0m.
Good luck.
[edit]Sorry, you need to use work-energy here. The force applied over a distance is work which must be factored in. Basically, PE1+KE1+W=PE2+KE2.
To calculate the potential energy at x = 2.0 m, we can use the formula for potential energy:
PE = -∫F(x)dx
Since the force is given by F = (-2.9)x + (-4.8)x^2, we can integrate it to get:
PE = -∫((-2.9)x + (-4.8)x^2)dx
PE = -(-1.45x^2 - 1.6x^3) + C
Since we are given that the potential energy is zero at x = 0, we can set C = 0.
Therefore, the potential energy at x = 2.0 m is:
PE = -(-1.45(2.0)^2 - 1.6(2.0)^3) = 18.6 J
For the second part of the question, we can use the conservation of energy principle:
KE + PE = constant
At x = 5.0 m, the potential energy is zero (since we set it to be zero at x = 0) and the kinetic energy is given by:
KE = 1/2mv^2
We are given that the object has a velocity of 5.0 m/s in the negative direction of the x-axis, so we can plug in the values to get:
1/2(16)(5.0)^2 = 200 J
This is the total energy of the system at x = 5.0 m.
When the object passes through the origin (x = 0), the potential energy will still be zero, but the kinetic energy will be:
KE = 200 - PE = 200 - 0 = 200 J
To find the speed, we can plug in the values to the kinetic energy formula:
KE = 1/2mv^2
200 = 1/2(16)v^2
v = √(200/8) = 5 m/s
Therefore, the speed of the object when it passes through the origin is 5 m/s.
