Understanding Quasi-Static Process: Work and Temperature Changes
  • Context: Graduate
  • Thread starter Thread starter spaghetti3451
    Process Quasi-static
The discussion centers on the quasi-static expansion of a gas, particularly focusing on the relationship between work done, temperature changes, and the conditions of the surroundings during the process. The scope includes theoretical considerations and applications related to adiabatic processes and ideal gases.
  • One participant suggests that during a quasi-static expansion, work is done until the internal pressure equals the external pressure, prompting a question about temperature changes in the system and surroundings.
  • Another participant asserts that the process is adiabatic and provides equations for ideal gases, noting that temperature changes depend on the specific conditions of the surroundings.
  • There is a discussion about whether temperature changes occur based on how energy is utilized in the surroundings, with examples provided such as lifting a weight versus running a heating coil.
  • A participant questions the applicability of the ideal gas assumptions to more general cases and seeks to understand if there is a general adiabatic condition.
  • Further inquiry is made regarding the implications of storing work output on heat flow to the surroundings.
Participants express varying views on the conditions under which temperature changes occur, with no consensus reached on the general case beyond ideal gases. The discussion remains unresolved regarding the broader implications of energy storage and its effects on temperature.
Limitations include the dependence on the equation of state of the gas and the specific conditions of the surroundings, which are not fully defined in the discussion.
spaghetti3451
Consider a quasi-static expansion of a gas. If you change the external force by dFext, then the system will do work on the surroundings until the internal pressure equals the external pressure, right?
Now, how does the temperature of the system and the surroundings chnage in the process?
Thanks for any help
Science news on Phys.org
This is an adiabatic expansion. So the adiabatic condition applies. If it is an ideal gas, then:
[tex]P_fV_f^\gamma = P_iV_i^\gamma[/tex] and
[tex]T_fV_f^{\gamma - 1} =T_iV_i^{\gamma - 1}[/tex]
where [itex]\gamma[/itex] is the ratio of specific heats: Cp/Cv
As far as the surroundings are concerned, it depends on the surroundings. Work is done on the surroundings. That may or may not change the temperature of the surroundings. For example, it might lift a weight in which case no temperature change occurrs. Or it may run a heating coil in an insulated container, in which case T increases.
AM
I see! So, if the pressure increases, the temperature increases and vice-versa.
But that's for an ideal gas only. What happens in the most general case? Is there any way to predict?
Also, is there a general adiabatic condition?
I see! So you are saying that whether the temperature changes depends on the way the energy is used in the surroundings. But what if the energy is simply stored?
It depends on the equation of state of the gas. It will be close.
If the work output is stored (say by lifting a weight) then would there be heat flow to the surroundings?
AM
  • · Replies 21 ·
  • · Replies 60 ·
11K
  • · Replies 22 ·
