Wood Movement Due to Rubber vs. Aluminum Bullet Impact: Explanation
  • Thread starter Thread starter butz3
The discussion centers on the impact of rubber and aluminum bullets on wooden blocks, specifically regarding momentum transfer. The rubber bullet, upon impact, transfers nearly all of its initial momentum to the wood and gains momentum in the opposite direction, resulting in greater movement of the wood. In contrast, the aluminum bullet burrows into the wood, retaining some of its momentum, which leads to less movement of the wood. Therefore, the rubber bullet causes the wood to move faster than the aluminum bullet.
  • Understanding of basic physics concepts such as momentum and energy transfer.
  • Familiarity with the properties of materials, specifically rubber and aluminum.
  • Knowledge of elastic and inelastic collisions.
  • Basic principles of mechanics related to projectile motion.
  • Research the principles of momentum conservation in elastic and inelastic collisions.
  • Study the physical properties of rubber and aluminum to understand their impact behavior.
  • Explore experiments demonstrating momentum transfer in collisions.
  • Learn about the mathematical equations governing momentum and kinetic energy.
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of collisions and material properties in impact scenarios.
butz3
two bullets of eqaul mass are shot at equal speeds at blocks of wood on a smooth ice rink. one bullet, made of rubber, bounces off the wood. the other bullet, made of aluminum, burrows into the wood. which bullet makes the wood move faster? why?
i said the rubber bullet will make the wood move faster, because it will transfer almost of it intial momentum to the wood. can some one please tell me if I'm right or way off thanks.
It's the rubber bullet, and you seem to have the right idea, but I'm not sure that your explanation is very good.
Basically, youre right:
The rubber bullet will not only transfer ALL it's initial momentum, it will also gain momentum in the opposite direction.
Hence, the momentum of the block will be greater or equal than the initial momentum of the rubber bullet.
The other bullet retains some of it initial momentum; hence, the resulting momentum of the block will be less than orequal to the initial momentum of the bullet..
14K
  • · Replies 16 ·
15K
  • · Replies 56 ·
10K
