New Reply
Alloy wheels and fuel economy
Share Thread Thread Tools
Apr6-11, 10:29 PM   #1
Will switching to alloy wheels (typically 17% lighter than steel) noticibly improve fuel economy? It seems like we should be able to calculate a rough estimate if we had necessary data but i don't. Has anyone been there?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr7-11, 06:53 AM   #2
Math 2012
Recognitions:
What proportion of the mass of a typical car is the wheels?
How much does a steel wheel (without the tire) weigh - say 20 pounds maximum? 20 x 4 x 0.17 = not much, compared with the total mass of the car.
The main difference would be the performance of the suspension, because you are reducing the mass being bounced around by bumps in the road. But if you can go faster round corners, your fuel consumption is likely to increase rather than decrease.
Apr7-11, 09:52 AM   #3
Wheels not only have to be accelerated linearly, but also angularly, which makes them harder to accelerate than regular car parts. Reducing rotating weight has a larger effect on fuel economy and performance than stationary weight. How much though...I never caluclated that. I'd be interested to know.
Apr7-11, 11:41 AM   #4
Mentor
I doubt it is substantial but because the savings is all during acceleration, most of the savings is in "city" driving.
Apr7-11, 12:56 PM   #5
But city driving is all stop and go, constantly accelerating and decelerating. I always thought that reducing the rotational mass would have a much greater effect than the cars overall mass. Due to the fact the wheels are directly propelled by the engine (well, not all depending on the drive).
Apr7-11, 03:42 PM   #6
Math 2012
Recognitions:
Quote by Lsos View Post
Suppose the radius of gyration of the wheel (without the tire) is = k. and the radius of the tire is r.
At a road speed of v, the translational kinetic energy of wheel = [itex]mv^2/2[/itex]
Angular velocity = v/r
Rotational kinetic energy of wheel = [itex]m(v/r)^2 k^2/2[/itex]
= [itex](k/r)^2 mv^2/2[/itex]
k/r must always be less than 1. I would guess a typical value would be about 0.7 which makes the rotational KE about half the translational KE.
If you add the rotational KE, 1.5 times "nothing much compared with KE of the rest of the car" is still "nothing much".
Apr8-11, 12:46 AM   #7
Recognitions:
Gold Membership Gold Member
depending upon the automobile..the increase in MPG is big...
1. anecdotal - friend of mine had a Chrysler 300 which had wheels and tires each weighed 50 lbs.,,cut the weight in half when we went to aluminum centerline wheels..the acceleration improved dramatically..opinion only
2. every pound of rotating weight you can remove, makes the car think you removed 10 pounds.
so in the above case, removing 25 pounds per wheel made the driver ' feel" like it lost 1000 pounds, seat of the pants, of course..
empirically, the formula means your using less gasoline to accelerate the lower moment of inertia wheels
Apr8-11, 06:32 AM   #8
Math 2012
Recognitions:
Quote by Ranger Mike View Post
I think that number is based on reducing high speed rotating masses like the flywheel, crankshaft, conrods, pistons, clutch plates, camshaft, etc.
Unless you are measuring how much faster you can spin the tires, the math doesn't stack up for the road wheels.
Lower unsprung mass = better suspension performance = more power on the road without wheelspin, but that isn't going to improve your gas consumption.
Apr8-11, 06:59 AM   #9
Recognitions:
Anytime you reduce weight of a vehicle , you get better MPG..it is a fact, even more savings is realized by reduction in ROTATION MASS...
High speed rotation parts is relative and the shear mass of 50 pound tires and wheels are a huge factor.
The calculations for the wheels are the same as regarding brake rotors, flywheels, and on a micro scale , crankshafts, cam shafts and axles..(gun drilled axles..yes, they do.)
Pistons and connecting rods are reciprocating weight and the rule does not apply. ( ok- 50% of a con rod would apply for big end only, if you want to get specific)
Apr8-11, 07:24 AM   #10
Math 2012
Recognitions:
The "high speed effect" is proportional to RPM squared.
If your engine is doing 6000 RPM and your road wheels 600, the rotationg engine parts are 100 times more significant than the wheels.
Sure, people will go for ever last little saving. The old Mississippi steamboat racing captains used to make their crews shave their heads bald to reduce wind resistance, I believe. I would expect the psychological effect of gun drilled axles on the race team is much more significant than anything Newton's laws would predict.
Apr8-11, 08:24 AM   #11
Recognitions:
AlephZero...good one!! ...i gotta remember that one!
i was in germany and saw th oil pump impeller for a Formulal 1 engine..it was carbon fiber..just to reduce rotation weight..now that is extreme!!
back to the math, typical race car in high gear will have tires rotating at 2016 ( 2.91 rear gear) to 3120 rpm ( 5.17 gear gear)...the real reason for going with light weight wheels is to minimize unsprung weight which can not be controlled when weight transfer occurs..the reduced moment of inertia is a good way to rationalize the purchase of a $ 400 magnesium wheel t hat will get cracked and dinged by the driver..insane but true..
screw it ,,im gonna shave my head now!!
Apr8-11, 05:15 PM   #12
Math 2012
Recognitions:
I deliberately chose a lower wheel RPM because I was thinking about the maximum acceleration coming out of a sharp corner etc. This is all about how fast the engine can spin up. Rotating mass doesn't have any effect on max speed. Neither does non-rotatiing mass, unless you change the shape of the car to reduce the air resistance.
Actually, air resistance from different shapes of wheel is another issue here - not my specialist subject, but I've been told that computational fluid dynamics models of cars include rotating wheels these days, to calculate the drag coefficient accuractely.
Apr9-11, 03:25 AM   #13
Recognitions:
Excellent point AlephZero
i was not aware of the newer programs capabilities...tires account for 40 percent of aero drag on open wheel cars...huge
thanks
Apr11-11, 12:23 PM   #14
Thanks AlephZero and everyone.
Apr11-11, 02:41 PM   #15
Recognitions:
Considering the Chrysler 300 weighs about 4100-4300 lbs, I seriously doubt it made any "dramatic" difference in the car's acceleration or fuel efficiency. A person's "butt-o-meter" is notoriously inaacurate in guessing a car's performance characteristics... My guess is there was no significant difference in 0-60, 1/4-mile, or MPG numbers.
This might be a general rule of thumb for an engine component rotating at thousands of RPM, but definitely not true for wheels and tires. Losing 1000lbs on a car is VERY significant, that would be a 25% reduction in total weight for that Chrysler...
I think you mean analytically or theroretically rather than empirically. Empirically would mean you tested it and measured a difference.
Quote by AlephZero View Post
It's true, race teams these days in F1 and NASCAR actually use "rolling road" wind tunnels, because both the wheels rolling at high speed and the road moving at the same speed as the wind makes a difference.
Apr11-11, 11:44 PM   #16
Here's a test:
http://www.carcraft.com/projectbuild...son/index.html
I assumed the numbers were accurate enough to be representative and used a 1/4 mile calculator to assess the changes in the quarter mile times and speeds. After baselining the calculator, I subtracted the weight reduction of the wheels (82 lbs) from the entered weight of the car (3882 lbs for simplicity) and the calculator predicted a drop from 12.14 sec @ 111.8 mph to 12.06 @ 112.2 mph.
Their result was 12.03 @ 113.11 mph; to get that same ET with the calculator required an extra 50 lb reduction. So the 82 lb reduction in wheel weight gave the same result as a 132 lb reduction in total vehicle weight, with 50 lbs worth due to reduction in rotating mass.
This is pretty crude and certainly shouldn't be taken as gospel, but it indicates that the effect is there, just not the magnitude that is usually stated.
Apr12-11, 12:14 AM   #17
The empirical numbers suggest 1.6; close enough!
New Reply
Thread Tools
Similar Threads for: Alloy wheels and fuel economy
Thread Forum Replies
Fuel Economy Booster Product Claims 4
best speed for fuel economy. General Physics 7
Aluminum alloy Grains, Which alloy is it? Materials & Chemical Engineering 1
'Plastic oil' could improve fuel economy in cars Chemistry 1
fuel economy gas vs ethanol Engineering, Comp Sci, & Technology Homework 0
