Is it possible to permanently demagnitize metal?
  • Context: Undergrad
  • Thread starter Thread starter joedango
    Metal
The discussion centers around the possibility of permanently demagnetizing a piece of metal, such as a paperclip or coin, that is initially magnetic. Participants explore various methods and the limitations of these approaches, including the concept of the Curie point and the need for continual external influences.
  • One participant inquires about methods to permanently remove the magnetic properties of a metal, noting that using the Curie point results in temporary demagnetization.
  • Several participants assert that there is no known technique to achieve permanent demagnetization without a continual external influence.
  • One participant suggests that using a demagnetizer could work if it provides a continual energy source for demagnetization.
  • Another participant proposes that melting the metal and combining it with a non-magnetic material could be a potential solution, but emphasizes that as long as the item is made from a magnetic material, it will remain magnetizable.
Participants generally agree that permanent demagnetization is not feasible without ongoing external influence, but there are differing views on the methods that could be employed to achieve demagnetization, particularly regarding the use of demagnetizers and the melting of metals.
Participants express uncertainty about the effectiveness of various methods and the conditions under which demagnetization might be achieved. The discussion does not resolve the technical details of the proposed methods.
joedango
For instance, let's say that i have a piece of metal (ie paperclip, coin, etc) that sticks to a magnet. Is there a way to remove its magnetic properties, so that it can't stick to metal?
Using curie point to demagnetize is only temporary. Is there a way to permanently demagnitize a magnetic metal (the metal can be at room temp. and not stick to a magnet).
Thanks
Science news on Phys.org
No.
You have already touched upon one technique to effect "temporary" de-magnetism. Good!
But, I know of no technique to make that "permanent" without a continual outside demagnetizing influence.
The only way would be to melt the metal down and combine it with something that is not magnetic as a whole. Pretty much no. As long as the paperclip or whatever item is made out of a magnetic material it will magnetize.
  • · Replies 0 ·
10K
  • · Replies 31 ·
  • · Replies 37 ·
  • · Replies 50 ·
