3-pin (Gas Discharge Tube) Surge arrester rating DC spark over voltage
The discussion centers on the rating and application of a 3-pin Gas Discharge Tube (GDT) surge arrester for public address audio equipment. The user is transitioning from a 2-pin to a 3-pin arrester to provide protection to Earth, seeking clarity on the 'DC spark-over' voltage ratings and whether a 250V 3-pin arrester is equivalent to a 500V 2-pin arrester. It is noted that the spark-over voltage for the 3-pin type is measured from each line to the center Earth pin, suggesting that a 250V rating would suffice for a 500V differential. The user is advised to verify this with customer support or through practical testing.
Sherlock_H
3-pin (Gas Discharge Tube) Surge arrester rating "DC spark over voltage"
Could someone please help with a question about Gas Discharge tube, surge arresters rating?
I am looking at a public address audio equipment which uses a 100vrms audio lines driven from a audio transformer. Currently the equipment has a single two pin epcos surge arrester placed across audio line, (It's blue and marked 500). This has a 'DC spark-over' voltage of 500V and discharge class of 20KA/20A.
I have been asked to change this so its protects down to Earth rather than just across the line. Because of a lack of space I have chosen to use an equivalent 3pin type, with the centre pin being the Earth connection.
I have two problems that are confusing me,
1. I am not sure whether the 'DC spark-over' rating of 3pin arrester is still rated between the end pins down to the centre pin or still across the end pins. So, is a 250V 3pin type is equivalent to a 500V two pin type?
2. Assuming the voltage between each line to Earth will be half the voltage that's between the audio lines, do I choose an arrester that's also half the voltage across the audio lines, i.e 250V instead of 500V (depending on the answer to first question).
Thanks.
Thanks.
Could you post links to the datasheets for the old and new arrestors? That would help us answer your questions. Thanks.
Thanks for the reply,
Apologies for the delay.
I believe this is the spec for the existing GDT, which is across the 100V audio lines.
http://www.epcos.com/inf/100/ds/a81a500xx1490.pdf
Reading on the epcos website it seems to me that the 3-pin types are more like
two separate GDT connected in series with the centre electrode as the common..
(Reference the link below)
"Test configuration for 3-electrode arresters:
The specified spark-over voltages, insulating resistance and capacitance refer to the respective measurements between one of the two wire electrodes (a/b) and the center
electrode (c).
Unless otherwise specified, the impulse or AC current is applied simultaneously from the two line electrodes to the center electrode with the defined value as the total current through the center electrode (c). "
http://www.epcos.com/web/generator/Web/Sections/ProductCatalog/ProtectionDevices/SurgeArresters/PDF__Arresters/PDFDefinitions,property=Data__en.pdf;/PDFDefinitions.pdf)
I'm still not sure what voltage to choose.
electrode (c).
From your 2nd link, it does sound like the arc-over voltage for the 3-pin devices is specified as each of the two fire voltages from the two electrodes (a/b) to the center electrode (c). So if you want a differential a-b fire voltage of 500V, you would use a 3-pin arrestor rated at 250V.
You may want to give their Customer Support folks a call to verify this, or if you can order a small quantity, just get some ane measure them yourself.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
