Definition of Normal (Intersection) Without Using a Metric
The discussion revolves around the concept of normal intersection of embedded manifolds without the explicit use of a metric. Participants explore definitions and implications of normal intersection in the context of differential topology and the geometry of manifolds.
  • One participant questions how to define normal intersection without a metric, suggesting that normality typically involves the orthogonality of tangent spaces at points of intersection.
  • Another participant proposes that the term "transversally" might be what is meant by normal intersection.
  • A participant clarifies that the author of the original statement distinguishes between normal and transverse intersections, indicating a specific use of terminology.
  • There is a mention of the ambient manifold, S^4, and the existence of a canonical metric derived from its embedding in Euclidean space.
  • One participant asserts that the definition of normal intersection aligns with the definition of transverse intersection, referencing a paper by Smale that uses this terminology.
  • Another participant notes that the article in question appears to be purely topological and does not utilize differential topology techniques, which may affect the interpretation of normal intersection.
Participants express differing interpretations of the term "normal intersection," with some suggesting it may be synonymous with "transverse intersection," while others maintain that the original context implies a distinct definition. The discussion remains unresolved regarding the precise definition and implications of normal intersection without a metric.
The discussion highlights the potential ambiguity in terminology and definitions within the context of manifold theory, particularly when metrics are not explicitly stated. The reliance on topological versus differential topology perspectives may also influence interpretations.
Bacle
Hi, Everyone:
I am trying to understand the meaning of a statement that two embedded manifolds
intersect normally*. The statement is made in a context in which any choice or existence
of a metric is not made explicit, nor--from what I can tell-- implicitly either.
If there was a choice of metric m, it seems reasonable to conclude that M,N
intersect normally if the tangent spaces at points of intersection are normal to
each other, i.e., if p is in the intersection, then TpM is orthogonal to TpN , with
respect to the metric given by m. Without a choice of m, it seems difficult to
see how to define normality of intersection. .
Is there then,a definition of normal intersection that does not make reference, or
does not make use of, the existence of a metric?
Thanks.
* More precisely, the statement is that M intersects N normally along DelM, the (manifold)
boundary of M
Could it be that they just mean "transversally"?
Thanks, Quasar, but i don't think so, since the author makes mention in another paragraph of manifolds being transverse; I would imagine s/he would have used
transverse in the paragraph I quoted.
What is the manifold in which they are embedded?
Quasar:
They are both embedded in S^4, the 4-sphere.
Well there is a canonical metric on S^4! Namely, the metric you get when you embed S^4 in the usual way and then restrict the euclidean metric to it. So when no metric is specified, it is safe to assume they mean the canonical metric.
Bacle said:
Hi, Everyone:
Thanks.
boundary of M
Normal intersection of two submanifolds means that at every point of the intersection the tangent spaces of the two submanifolds span the tangent space of the ambient manifold.
That's the definition of transverse intersection, no?
Quasar Wrote, in Part:
"Well there is a canonical metric on S^4! Namely, the metric you get when you embed S^4 in the usual way and then restrict the euclidean metric to it. So when no metric is specified, it is safe to assume they mean the canonical metric."
True, but the layout/format of the article seemed to be purely topological , i.e., did not
make use of differential-topology-type techniques.
Then, possibly the authors just mean "transverse", as lavinia suggested.
Thanks to both; sorry for the dead-end chase.
  • · Replies 19 ·
