Calculating Projectile Motion for a Catapult with Limited Data
The discussion revolves around a projectile motion problem related to a catapult project. The original poster has limited data, specifically a time interval of 1.1 seconds, a horizontal distance of 2.2 meters, and an angle of 70 degrees. There is uncertainty regarding the influence of a compression spring on the calculations.
  • Participants discuss the need to find the vertical displacement and both initial and final vertical velocities. There is a focus on identifying the appropriate equations of motion for the horizontal and vertical components of the projectile's trajectory.
Some participants have provided guidance on writing the equations of motion and have prompted the original poster to clarify their understanding of the problem. There is an ongoing exploration of the relationships between the variables involved, with no explicit consensus reached yet.
There is mention of potential discrepancies in the values provided, particularly regarding the horizontal distance, which some participants note as being inconsistent. The original poster expresses a lack of confidence in their understanding of physics, which may affect their approach to the problem.
thedarklite
Hi Guys
hope u r feeling good
i just finished my catapult project
and the problem is that i have only two given
and the problem is that i have only two given values the [tex]\Delta T = 1.1 sec.\Delta_{d}x=2.2 m[/tex], and the angle is 70' degrees. and nothing else.
http://tinypic.com/r/2ylqpux/7
i have tried to use the projectile motion equations but there was so many unknowns
what is confusing me more that i have the catapult powered by a compression spring and i don't know if that is effecting the calculations or not.
pleasezz i need help at this because I'm totally lost
Hi thedarklite, welcome to Physics Forums.
Please use the thread template when you post a question.
You haven't stated the complete problem; what is it you're trying to find/solve?
sorry for that gneill
but all what i need to find is the deltaYd and the Vyf and initial too but the problem this is my first time doing the catapult thingy and the problem is that i have a weak understanding of physics that is why i don't know how to approach this problem
Can you write the two equations of motion that describe the x and y motions of the projectile? The important thing to remember is that the x and y components (that is, the horizontal and vertical motions) of the projectile are independent of each other.
i think i am suppose to find the final and initial velocity of the y component i think i also need to find the maximum height of the y component
and i don't know which equations to use
What equations of motion do you know? For a constant velocity v, what is the expression for the distance versus time? How about when there's an initial velocity and an acceleration?
so that is the solution that i tried
Variables:
∆dx=2.1 m ∆t=1.1 s V_ix= ? V_iy= ? V_fy= ? a_y= ?
∆dy=0.0275 m
V_ix= ∆dx⁄∆t V_ix= (2.1 m)⁄(1.1 s)
∴V_ix= 1.9 m⁄s
V_iy= V_ix tan⁡〖70°〗 V_iy=(1.9 m⁄s) tan⁡〖70°〗,
∴V_iy=5.2 m⁄s
∆dy= V_iy ∆t+ 1/2 a_y (∆t)^2 0.0275m=(5.2 m⁄s)(1.1s)+ 1/2 a_y (1.1s)^2
∴a_y=-9.4 m⁄s^2
〖V_fy〗^2= 〖V_iy〗^2+2a_y ∆dy V_fy= √((5.2 m⁄s)^2+2(-9.4 m⁄s^2 )(0.0275m) )
∴V_fy=5.1 m⁄s since V_ix= V_fx ∴V_fx=1.9 m⁄s
V= √(〖V_fy〗^2+ 〖V_fx〗^2 ) V= √((5.1)^2+ (1.9)^2 ) ∴V=5.4 m⁄s
tan^(-1)⁡〖5.1/1.9〗= 70°,tan^(-1)⁡〖1.9/5.1〗=20°
∴V=5.4 m⁄s [W 70° N] or V=5.4 m⁄s [S 20° E]
Your original problem statement seemed to indicate that the total x-distance was 2.2m, not 2.1m. So the velocity in the x-direction should be 2.2m / 1.1s = 2.0 m/s.
With the x-component of the velocity and the angle, you should be able to find the initial y-component of the velocity.
  • · Replies 16 ·
  • · Replies 23 ·
11K
15K
