Uncovering the Mystery of Euclid's Proof of Infinite Primes
  • Context: Undergrad
  • Thread starter Thread starter cragar
    Infinite Primes
The discussion revolves around Euclid's proof of the infinitude of prime numbers, specifically examining the construction of a number Q from a finite list of primes and the implications of adding 1 to this product. Participants explore the nature of the resulting number and its relationship to the original list of primes.
  • One participant questions why the divisor of Q+1 must be a prime number, suggesting that it could be even instead.
  • Another participant references the Fundamental Theorem of Arithmetic, asserting that since no primes divide Q, it must be prime.
  • A participant reiterates the construction of Q and its properties, emphasizing that Q is odd when derived from an even product of primes.
  • There is a discussion about the implications of dividing Q by any prime in the list, leading to a remainder of 1, and whether this guarantees that Q+1 is prime or has a larger prime factor.
  • One participant explains that every integer greater than 1 must have at least one prime factor, which implies that Q+1 must contain a prime factor not in the original list.
  • Another participant suggests a mathematical approach to prove that (a*b + 1) is not divisible by any of the primes a, b, etc., using modular arithmetic.
Participants express varying levels of understanding and interpretation of Euclid's proof, with some agreeing on the implications of Q+1 containing a prime factor not in the original list, while others remain uncertain about specific aspects of the proof. The discussion does not reach a consensus on all points raised.
Some participants express confusion about the divisibility of Q+1 and the nature of its factors, indicating that assumptions about prime factors and their properties are not fully resolved. The discussion includes references to modular arithmetic without complete agreement on its implications.
Readers interested in number theory, the properties of prime numbers, and historical proofs in mathematics may find this discussion relevant.
cragar
I am trying to understand Euclid's proof of infinite primes. So let's say we have a finite list of primes n1, n2 ... N where N is the largest prime .
Then we take the product of all of these prime numbers, and we will call it Q .
Then we add 1 to it . so this number is either prime or not . If it is prime then we have one more that isn't in our list. But then if it isn't prime, then some larger prime will divide it .
But why can't the number that divides it be even why does it have to be a prime number that can divide it? It is probably simple but I don't see it .
Mathematics news on Phys.org
The Fundamental Theorem of Arithmetic states that all integers greater than 1 can be written as a unique product of prime factors.
Since no primes divide Q, it follows that Q must be prime.
Because n1 (or n2, depending how you start) = 2. So n1*n2*...*N is an even number. Add 1 to that, you have an odd number.
thanks for your responses. If we divide our list by any numbers in the list we will have a remainder of 1 , So does this means that Q+1 is a prime number or divisible by a larger prime number because no other division would leave us with a remainder of 1?
Hi Cragar. Every integer >1 must have at least one prime factor. If the number itself is a prime then that's the only factor (apart from 1), if it's a non-prime then it's got at least two prime factors. So they all have at least one prime factor!
So quite simply since our new number "Q+1" contains at least one prime factor (as do all numbers >1), and since none of the primes on our list are candidates, then this implies that there must be at least one more prime [itex](\leq \, Q+1)[/itex] that is not already on our list. In effect this mean that no matter how extensive is our list we can always prove that it's not complete.
thanks everyone for your replies and uart that really cleared it up.
you have to prove that ( a*b + 1 ) is not divisible by a or b, and the same for like (a*b*c*d*e*f*g + 1) is not divisible by a,b,c,d,e,f,g. (and of course they are not equal to one)
this is done really easily if you say that a*(...) ≡ 0 (mod a), then a*(...) + 1 ≡ 0+1 ≡ 1 (mod a). so if it is not 0 (mod a), then it is not divisible by a, so it is not divisible by any of the others. this is sort of obvious, but it might not be that obvious at first...
okay that helps too, thanks
  • · Replies 0 ·
  • · Replies 35 ·
  • · Replies 16 ·
