Calculating Jet Engine Output of an Airplane
The discussion focuses on calculating the jet engine output of an airplane, specifically analyzing thrust and power. The thrust due to ejected fuel is calculated as 2,310 N, derived from the mass flow rate of fuel (4.2 kg/s) multiplied by the exhaust speed (550 m/s). Additionally, the thrust due to accelerated air is determined to be 55,000 N, based on the change in momentum of the air entering and exiting the engine. The total power delivered by the jet engine is approximately 20,200 horsepower, calculated from the combined thrust and the velocity of the airplane (270 m/s).
  • Understanding of Newton's laws of motion
  • Basic knowledge of momentum and thrust calculations
  • Familiarity with power calculations in physics
  • Knowledge of jet engine operation principles
  • Research the principles of thrust generation in jet engines
  • Learn about the relationship between thrust and power in aerospace engineering
  • Explore advanced momentum analysis techniques for fluid dynamics
  • Study the impact of airspeed on jet engine performance
Aerospace engineers, physics students, and aviation enthusiasts interested in understanding jet engine performance and calculations related to thrust and power output.
physicsss
The jet engine of an airplane takes in 100 kg of air per second, which is burned with 4.2 kg of fuel per second. The burned gases leave the plane at a speed of 550 m/s (relative to the plane). If the plane is traveling 270 m/s.
(a) Determine the thrust due to ejected fuel.
This is just 4.2*550
(b) Determine the thrust due to accelerated air passing through the engine.
(c) Determine the power (hp) delivered.
(b) The air comes in at 270 m/s and comes out at 550 m/s. You know the mass of the air, so you can calculate the thrust.
(a) The thrust due to ejected fuel can be calculated by multiplying the mass flow rate of fuel (4.2 kg/s) by the speed of the exhaust gases (550 m/s). Therefore, the thrust due to ejected fuel is 2,310 N (Newtons).
(b) To determine the thrust due to accelerated air passing through the engine, we need to calculate the change in momentum of the air. The momentum of the air entering the engine is 100 kg/s * 270 m/s = 27,000 kg*m/s. The momentum of the air leaving the engine is 100 kg/s * (270 m/s + 550 m/s) = 82,000 kg*m/s. The change in momentum is 82,000 kg*m/s - 27,000 kg*m/s = 55,000 kg*m/s. This results in a thrust of 55,000 N.
(c) The power delivered by the jet engine can be calculated by multiplying the thrust (in Newtons) by the velocity of the plane (in meters per second). Therefore, the power delivered is (2,310 N + 55,000 N) * 270 m/s = 15,057,000 watts. This is equivalent to approximately 20,200 horsepower.
