Characteristic polynomial of a matrix
The characteristic polynomial of an nxn matrix A with all entries equal to 1 is given by the formula f(t) = (-1)^n t^(n-1) (t - n). This conclusion is reached by analyzing the eigenvalues of the matrix, where the null space yields an eigenvalue of 0, and the remaining eigenvalue can be identified through the image of A. The determinant can be computed using the formula det(A) = ε_{i_1i_2...i_N} A_{i_11} A_{i_22}... A_{i_NN}, where A_{ij} = 1 - tδ_{ij}. This approach is supported by concepts from invariant subspaces.
  • Understanding of characteristic polynomials
  • Familiarity with eigenvalues and eigenvectors
  • Knowledge of determinants and matrix operations
  • Basic concepts of invariant subspaces
  • Study the derivation of characteristic polynomials for different matrix types
  • Learn about eigenvalue decomposition and its applications
  • Explore the properties of determinants in linear algebra
  • Investigate invariant subspaces and their significance in matrix theory
Students of linear algebra, mathematicians focusing on matrix theory, and anyone interested in understanding the properties of characteristic polynomials and eigenvalues.
ptolema
Let A be an nxn matrix with real number entries, in which all entries are 1. Find the characteristic polynomial of A.
characteristic polynomial: f(t)=det(A-tI), I is identity matrix
I've tried to do this by various methods of induction, only to encounter massive blocks along the way. I can't really do anything with this past plug in numbers and hope something works. I know the equation should be (-1)ntn-1(t-n), but I don't know how to prove it. This is from a section of my book on invariant subspaces, is there anything I could do with those?
I have a suggestion, though it may be misguided. Try finding the null space and image of A. The vectors that span the null space are eigenvectors with eigenvalue 0. From the image, you should be able to identify the remaining eigenvector and its eigenvalue. From that, you can deduce everything except the factor of (-1)n.
Well, one way to do it is to use the formula for determinant
[tex] det A = \epsilon_{i_1i_2...i_N}A_{i_11}A_{i_22}...A_{i_NN}[/tex]
For your case [itex]A_{ij} = 1 - t\delta_{ij}[/itex]
Also useful, will be the fact
[tex]\sum\limits_{i=1}^N\sum\limits_{j=1}^N \epsilon_{ijklm...} = 0[/tex]
  • · Replies 19 ·
