Is a uniform limit of absolutely continuous functions absolutely continuous?
The discussion centers around the claim that a uniform limit of absolutely continuous functions is absolutely continuous. Participants explore this concept through the example of the Cantor function, examining whether it serves as a uniform limit of absolutely continuous functions and the implications of this for the original claim.
  • One participant questions the truth of the claim that a uniform limit of absolutely continuous functions is absolutely continuous, using the Cantor function as a counterexample.
  • Another participant asks if the Cantor function is indeed a uniform limit of the sequence of functions that converge to it.
  • It is noted that the Cantor function is not absolutely continuous, which raises concerns about the validity of the original claim.
  • A participant asserts that uniform convergence of absolutely continuous functions does not imply that the limit function is absolutely continuous unless additional conditions are met.
  • One participant confirms that the Cantor function is the uniform limit of absolutely continuous functions, suggesting a potential resolution to the inquiry.
Participants express disagreement regarding the implications of uniform convergence on absolute continuity. While some assert that the Cantor function is a uniform limit of absolutely continuous functions, others emphasize that this does not guarantee absolute continuity, leading to an unresolved discussion.
There are unresolved assumptions regarding the conditions under which uniform limits maintain absolute continuity, as well as the specific properties of the functions involved in the discussion.
AxiomOfChoice
I was reading a Ph.D. thesis this morning and came across the claim that "a uniform limit of absolutely continuous functions is absolutely continuous." Is this true? What about the sequence of functions that converges to the Cantor function on [0,1]? Each of those functions is absolutely continuous, right? And they converge uniformly to the Cantor function, right? But the Cantor function is the canonical example of a continuous, increasing function that's not absolutely continuous!
Just so you know what I mean, I'm talking about the sequence [itex]\{ g_n(x) \}[/itex], where [itex]g_n[/itex] is constant on the middle-third that is removed in stage [itex]n[/itex] of constructing the Cantor set, and linear everywhere else. For example:
[tex] g_1(x) = \begin{cases} \frac{3x}{2}, & x\in [0,1/3],\\ \frac 12, & x\in (1/3,2/3),\\ \frac{3x}{2} - \frac 12, & x\in [2/3,1]. \end{cases}[/tex]
This guy is clearly the integral of his derivative, so I think it's reasonable to conclude that each of the other ones is, too.
(As an aside...isn't it true that any function that is some piecewise combination of constant and linear functions is absolutely continuous on a closed, bounded interval?)
I haven't checked it out, but is the Cantor function a UNIFORM limit?
Yes, that is correct (assuming that the segments meet at the endpoints, of course). And your reasoning in the OP is correct as well. Uniform convergence of absolutely continuous functions does not, by itself, imply convergence. So unless your Ph. D. included some other condition on the functions (such as the derivatives also converging uniformly, or at least being uniformly bounded above by some integrable function), then (s)he is quite in error. Hopefully their thesis did not depend on that assertion!
TylerH said:
This Cantor function isn't absolutely continuous. http://en.wikipedia.org/wiki/Cantor_function
You misunderstood my comment. I was wondering iif the Cantor function was a UNIFORM limit of absolutely continuous functions. I am well aware of the fact that it is not absolutely continuous.
I checked further. The Cantor function is the uniform limit of absolutely continuous functions.
  • · Replies 18 ·
  • · Replies 40 ·
