Indium tin oxide - thickness question
  • Thread starter Thread starter johng23
    Thickness
The thickness of Indium Tin Oxide (ITO) films significantly impacts their performance, balancing transparency and conductivity. Research indicates that ITO can remain reasonably transparent to visible light at thicknesses up to 1 micron, with transmittance data primarily available up to 500 nm. For thicker films, specifically in the range of 5-15 microns, suitable deposition methods such as sputtering or pulsed laser deposition (PLD) are recommended to achieve desired characteristics without compromising transparency.
  • Understanding of ITO film properties and applications
  • Familiarity with optical transmittance measurements
  • Knowledge of deposition techniques such as sputtering and pulsed laser deposition
  • Basic principles of thin film optics
  • Research the optical properties of ITO films at various thicknesses
  • Learn about sputtering techniques for depositing thick ITO films
  • Investigate pulsed laser deposition (PLD) for ITO applications
  • Explore the trade-offs between conductivity and transparency in ITO films
Materials scientists, optical engineers, and professionals involved in the fabrication of transparent conductive films will benefit from this discussion.
johng23
I read that the thickness of an ITO film affects performance as a trade off between transparency and conductivity. How thick can ITO be and still remain reasonably transparent to visible light? I found a couple papers which characterize the transmittance but only out to 500 nm or so. Could it be a couple microns thick and still transmit most visible light (400 or 800 nm wavelength)?
Forget that - could anyone tell me which deposition method would be suitable for depositing a 5-10 micron film? Or even 15?
  • · Replies 0 ·
  • · Replies 20 ·
51K
