How to Determine the Total Cross Section for an Isotropic Reaction?
The discussion focuses on calculating the total cross section for an isotropic reaction involving a 1 mg/cm² target of 48-Ca bombarded by a 10-nA beam of alpha particles. The detector, with a solid angle of 2E-3 steradians, records 15 protons per second. To determine the total cross section in millibarns (mb), one must first calculate the flux and the number of scattering centers, then apply the relationship between the differential cross section and the solid angle. The total cross section can be derived by multiplying the differential cross section by the solid angle factor.
  • Understanding of isotropic reactions in nuclear physics
  • Knowledge of solid angles and their calculations
  • Familiarity with cross section concepts in particle physics
  • Ability to perform calculations involving flux and scattering centers
  • Study the derivation of the differential cross section in isotropic scattering
  • Learn about the relationship between solid angle and total cross section
  • Explore the concept of flux in particle physics
  • Investigate the application of the formula for total cross section in various nuclear reactions
Students and researchers in nuclear physics, particularly those focusing on reaction cross sections and isotropic scattering phenomena.
jack7992
A thin (1mg/cm^2) target of 48-Ca is bombarded with a 10-nA bean of alpha particles. A detector, subtending a solid angle of 2E-3 steradians, records 15 protons per second. If the angular distribution is isotropic, determine the total cross section, in mb, for the reaction. You can take the atomic mass of 48-Ca to be A= 48.
I know basically how to do this problem. I can calculate flux, number of scattering centers, etc. The only thing I am getting hung up on is the solid angle idea. From my understanding, this is basically saying that a detector with a solid angle of 2E-3 str detects 15 protons/sec., which is only a portion of the total deflected. I can get the differential cross section. My question is how do you get the total cross section. Do you just multiply by a str factor or something? Thanks a lot!
I am not sure what cross section you are trying to find but...
an angle is the ratio of the length of the arc to the radius, similarly, the solid angle is the ratio of the area subtended to its radius squared. The area of a part of a sphere is
[tex]S=\int\int r^2 \sin{\theta} \, d\theta d\phi[/tex]
, therefore, the solid angle is just
[tex]d\Omega= \int \int \sin{\theta} \, d\theta d\phi[/tex]
and if you do the integration over all [tex]\phi[/tex] and all [tex]\theta[/tex] you will get [tex]4 \pi[/tex] which is the total solid angle of a sphere. Of course if you multiply this by [tex]r^2[/tex] you will get the area of a sphere.
  • · Replies 0 ·
  • · Replies 94 ·
15K
