Solving a Puzzling Problem: A Disk and a Hoop
  • Context: Undergrad
  • Thread starter Thread starter Geoffrey F. Miller
    Disk
The discussion revolves around the conceptual problem of why a disk rolls faster than a hoop when both are rolled down a hill, despite having the same mass. Participants explore the concepts of rotational inertia and moment of inertia, as well as the implications of mass distribution in relation to rotational motion.
  • One participant notes the difference in rolling speeds between a disk and a hoop, prompting the question of why this occurs.
  • Another participant questions which object has greater rotational inertia, suggesting that the hoop likely has a greater moment of inertia.
  • A participant provides a detailed explanation of how moment of inertia is calculated for both a hoop and a disk, indicating that the hoop's moment of inertia is greater due to its mass distribution.
  • Concerns are raised about whether the problem specifies that the disk and hoop have the same radius, with some participants asserting that it does not matter.
  • One participant emphasizes that rotational inertia depends on the distribution of mass, stating that more mass farther from the axis increases rotational inertia.
Participants express differing views on the relevance of the radius in the problem, with some asserting it does not matter while others believe it should be considered. There is no consensus on the implications of the radius on the rolling behavior of the disk and hoop.
Participants discuss the moment of inertia calculations in detail, but there are unresolved assumptions regarding the conditions of the problem, such as the radius of the disk and hoop.
Geoffrey F. Miller
I'm having some trouble with a conceptual problem. Your help or input would be greatly appreciated. Here's the problem.
A disk and a hoop, both having the same mass, are rolled down a hill. The disk rolls faster than the hoop. Why is this so?
Thank you for your time!
Which one has the greater rotational inertia? (And thus is harder to get rolling.)
I guess the hoop would have a greater moment of inertia, but why is it greater? How is rotational inertia calculated?
Moment of Inertia
[tex]I = \sum_{i=1}^{n} m_{i} r_{i}^2[/tex]
For a a system composed of particles with defined mass the above can be calculated easily, but for a continuous mass system we will take a small mass [itex]\Delta m [/tex] and applying the moment of inertia definition we should get.<br /> <br /> [tex]I = \lim_{n \rightarrow \infty} \sum_{i=1}^{n} \Delta m_{i} r_{i}^2[/tex]<br /> <br /> Which is the integral of an infinitessimal mass<br /> <br /> [tex]I = \int r^2 dm[/tex]<br /> <br /> Now the moment of inertia around the z axis for a Uniform hoop is <br /> <br /> [tex]I_{z} = \int r^2 dm[/tex]<br /> <br /> every particle with mass dm is at a constant distance R, so<br /> <br /> [tex]I_{z} = R^2 \int dm[/tex]<br /> <br /> [tex]I_{z} = MR^2[/tex]<br /> <br /> For more detail we could calculate the moment of inertia for ring shaped cylinder will be:<br /> <br /> [tex]I_{z} = \int r^2 dm[/tex]<br /> <br /> Using <br /> <br /> [tex]\rho = \frac{dm}{dV}[/tex]<br /> <br /> [tex]I_{z} = \int r^2 \rho dV[/tex]<br /> <br /> Applying cylindric shells we get, where L is the height of our cylinder<br /> <br /> [tex]dV = 2 \pi r dr L[/tex]<br /> <br /> so<br /> <br /> [tex]I_{z} = 2 \pi L \rho \int^{r}_{r_{o}} r^3 dr[/tex]<br /> <br /> we get<br /> <br /> [tex]I_{z} = \frac{1}{2} M(r^2 + r_{o}^2)[/tex]<br /> <br /> A hoop can be considered a ring shaped cylinder of very thin walls so we could say<br /> <br /> [tex]I_{z} = MR^2[/tex]<br /> <br /> Now an uniform disk could be considered a solid cylinder so<br /> <br /> [tex]I_{z} = \int r^2 dm[/tex]<br /> <br /> r being the radius of our cylinder<br /> <br /> Using <br /> [tex]\rho = \frac{dm}{dV}[/tex]<br /> <br /> <br /> [tex]I_{z} = \int r^2 \rho dV[/tex]<br /> <br /> Applying [itex]dV = dA L[/itex]<br /> <br /> [tex]I_{z} = \int r^2 \rho 2 r \pi L dr[/tex]<br /> <br /> [tex]I_{z} = \int r^3 \rho 2 \pi L dr[/tex]<br /> <br /> [tex]I_{z} = \rho 2 \pi L \int^{r}_{0} r^3 dr[/tex]<br /> <br /> [tex]I_{z} = \frac{1}{2} MR^2[/tex]<br /> <br /> Note: All the z- axis go through the center of mass<br /> <br /> Also:<br /> <br /> Moment of Inertia for the disk<br /> [tex]I_{z} = \frac{1}{2} MR^2[/tex]<br /> <br /> Moment of Inertia for the hoop<br /> [tex]I_{z} = MR^2[/tex]<br /> <br /> From this two moment of inertia you can see which will get down before the other.<br /> <br /> and i found this movie for this:<br /> <a href="http://solomon.physics.sc.edu/~tedeschi/demo/demo12.html" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://solomon.physics.sc.edu/~tedeschi/demo/demo12.html</a>[/itex]
Did the problem specify that the disk and hoop have the same radius?
Cyclovenom gave the details, but the gist of it is that rotational inertia depends on how the mass is distributed: The more mass farther from the rotational axis, the greater the rotational inertia. It's harder to rotate something if its mass is far from the axis of rotation.
It doesn't matter.
Doc Al said:
It doesn't matter.
I thought it would be something Geoff should think about! :smile:
An excellent point! :biggrin:
  • · Replies 37 ·
  • · Replies 19 ·
