Elctromagnetic induction by a solenoid moving with the speed of light?
The discussion revolves around the concept of electromagnetic induction in scenarios involving a solenoid and a magnet moving at the speed of light. Participants explore the implications of such a scenario on Faraday's law and the principles of relativity, questioning the feasibility and logical consistency of the premises involved.
  • One participant proposes a thought experiment involving a magnet moving at the speed of light and questions whether electromagnetic induction would occur in a solenoid under these conditions.
  • Another participant argues that moving a magnet at the speed of light is physically impossible, suggesting that the premise leads to contradictions.
  • Some participants acknowledge the unrealistic nature of the scenario but express a desire to explore ideas beyond established laws of physics.
  • A participant discusses the logical implications of special relativity, stating that if a solenoid could move at the speed of light, it would violate the principles of relativity.
  • There is a suggestion to consider a more realistic scenario, such as a solenoid moving at half the speed of light, to analyze the effects on electromagnetic induction.
Participants generally agree that the scenario presented is not realistic and that the assumptions lead to contradictions. However, there is a divergence in opinions regarding the value of exploring such thought experiments and the implications for the principles of relativity.
The discussion includes unresolved assumptions about the nature of electromagnetic induction and the limitations of applying special relativity to hypothetical scenarios involving superluminal speeds.
A Dhingra
Elctromagnetic induction by a solenoid moving with the speed of light??
The moment the magnetic field is generated, it should take some time to reach some distance. It cannot reach infinity instantly, it should have some speed, and that speed cannot be more than that of light. So let’s say that the newly generated magnetic field, through a current carrying wire, travels with the speed of light. Now for the application of the faraday’s law, let’s bring a magnet near a solenoid, through which initially no current flows, and make the magnet move with the speed of light. Will there be electromagnetic induction observed in this case?
Take another case, when instead of a magnet we have a different circuit containing a solenoid through which current flows when the switch is made on, and this circuit is held stationary moving the other one with the speed of light. Will there be electromagnetic induction observed in this case? What I think is that, as the system without current is moving as fast as the magnetic field … it never gets the chance to cut the magnetic field and cause induction to occur in the solenoid. So there should be no induction. But there is relative motion between the two systems and (also there is NO time varying magnetic field through the moving solenoid,)AND no induced current will be produced ...
so will the induction take place or not...??
if induction does not take place then the principle or relativity goes wrong...
You cannot make a magnet move with the speed of light. It is a physically impossible premise, so you shouldn't be surprised that assuming it leads to contradictions.
... can't it be just a thought experiment like many other paradoxes available...
with that assumption, think about the result...
No, think about the question:
A Dhingra said:
make the magnet move with the speed of light. ... then the principle or relativity goes wrong...
Obviously, if you violate the principle of relativity in your question then the answer must be that the principle of relativity is violated. It is just the most basic logic. Non-physical assumptions lead to non-physical conclusions. This says nothing whatsoever about physics, only about your question.
ok...
i agree that the situation is not realistic...
but still i didn't like the fact that one should not think beyond the laws made by humans himself...
This is elementary logic. If you have any set of axioms (A) which logically imply some result (B) then if your premise is not(B) then you must logically conclude not(A). This is called transposition and is one of the fundamental rules of logic: http://en.wikipedia.org/wiki/Transposition_(logic )
SR logically implies that a solenoid must move slower than light (STL), therefore if you assume that a solenoid can move with the speed of light you must logically conclude that special relativity (SR) is violated. Written in the usual format for logic:
(SR → STL) ↔ (~STL → ~SR)
Whether or not the situation is realistic and whether or not SR is a "law made by humans himself" is actually only a secondary concern. This is primarily an exercise in basic logic. Note that I am agreeing with your OP. Under the stated premise (~STL) you must indeed logically conclude that "the principle of relativity goes wrong" (~SR).
to make the experiment fair you would have to calculate what would happen to the solenoid at half light speed and then go from there.
A Dhingra said:
ok...
If you want to think beyond relativity, invent your own laws of physics. If you want to explain in terms of relativity, then think within relativity.
can you help me go about finding this result...
(considering the magnetic field to be varying with time ... as it is getting produced .)
  • · Replies 16 ·
