Evaluating Continued Fraction: \langle 1, 2, 1, 2, \ldots \rangle
  • Context: Undergrad
  • Thread starter Thread starter math_grl
    Fractions
The discussion revolves around evaluating the continued fraction \langle 1, 2, 1, 2, \ldots \rangle. Participants explore the formulation of the equation and the resulting solutions, focusing on the correctness of the approach and the final answer.
  • Technical explanation, Debate/contested, Homework-related
  • One participant presents an equation for the continued fraction and derives a quadratic equation, leading to a proposed solution of x = \frac{-1 + \sqrt{13}}{2}.
  • Another participant challenges the formulation of the equation, suggesting it should be x = 1 + \frac{1}{2 + \frac{1}{x}} instead.
  • A later reply expresses embarrassment over the initial mistake in the equation.
  • There is a mention of difficulty in finding other examples of continued fractions to verify the computation.
Participants do not reach consensus on the correct formulation of the equation or the resulting solution, indicating a disagreement on the approach to evaluating the continued fraction.
The discussion highlights potential limitations in the initial equation setup and the reliance on specific formulations of continued fractions, which may affect the outcomes.
math_grl
Ok I need to know which is the right answer for evaluating the continued fraction [tex]\langle 1, 2, 1, 2, \ldots \rangle[/tex]?
Here's my work:
[tex]x = 1 + \frac{1}{2+x} \Rightarrow x^2 + x - 3 = 0[/tex] and by quadratic formula, we get [tex]x = \frac{-1 \pm \sqrt{13}}{2}[/tex] but we only want the positive root so I get [tex]x = \frac{-1 + \sqrt{13}}{2}[/tex] for my answer but the answer given was [tex]x = \frac{1 + \sqrt{3}}{2}[/tex], so I'm confused at which it is...
Moreover, I can't seem to find any other example except for [tex]\langle 1, 1, 1, \ldots \rangle[/tex] to see if I'm doing my computation right. Please help.
Your equation for x is incorrect. It should be
[tex]1 + \frac{1}{2 + \frac{1}{x}}[/tex]
:blushing:
that's embarassing.
You'll do better next time!
  • · Replies 21 ·
  • · Replies 25 ·
