Definition of variable coefficients in linear differential equations
The discussion revolves around the definition and characteristics of variable coefficients in linear differential equations. Participants explore whether these coefficients must be polynomials and examine specific examples, including trigonometric functions, while also discussing methods for solving such equations.
  • Exploratory, Technical explanation, Debate/contested, Homework-related
  • One participant questions whether variable coefficients in linear differential equations must be polynomials, citing the Cauchy–Euler equation as an example.
  • Another participant asserts that an equation is linear if all functions of the dependent variable y appear only to the first power, providing a general form of a second-order linear differential equation.
  • Several participants agree that the example provided, involving sine and cosine functions, is indeed a linear differential equation.
  • It is noted that coefficients can be any functions of the independent variable x, not limited to polynomials, although solving such equations can be complex.
  • A participant expresses uncertainty about solving a specific linear differential equation with cosine as a coefficient and contemplates using a power series and Laplace transform, seeking guidance on the approach.
Participants generally agree that the equation with trigonometric coefficients is linear, but there is no consensus on the best method for solving such equations, particularly when involving non-polynomial coefficients.
Some participants highlight the complexity of solving linear differential equations with variable coefficients, especially when those coefficients are non-polynomial functions like sine or cosine.
tiredryan
The way to tell if it is linear or not is to look at the functions (including derivatives) of y.
The equation is linear in y if all functions of y are in the first power.
That is y'', y', y occur but (y'')2 ; (y')2 ; (y)2 do not occur.
The general second order linear differential equation is
[tex]l\left( x \right)\frac{{{d^2}y}}{{d{x^2}}} + m\left( x \right)\frac{{dy}}{{dx}} + n\left( x \right)y = g\left( x \right)[/tex]
Where l(x), m(x), n(x) and g(x) are functions of x only.
So your example is linear.
go well
Yes, it is linear.
Yes, if we have a linear differential equation with variable coefficients with dependent variable y and independent variable x, then the coefficients may be any functions of x.
Of course, even with polynomial coefficents, such an equation can become very difficult to solve.
Hi everybody,
I just wanted to ask how can I solve such problems when the coefficient is a sin or cos?
What method should I use? My problem is
y'''+y''+y'+cos(x)y=0
and I don't even know how to start solving it. I was thinking I could replace cos with its power series and then take its laplace transform but that's way too long. I don't know if it would work anyway. Please help.
P.S. I didn't include the non-homogeneous term.
