Question about Big-O functions.
  • Context: Undergrad
  • Thread starter Thread starter reef
    Functions
The discussion revolves around the concept of big-O notation in mathematics, specifically regarding the establishment of witnesses for big-O functions. Participants explore the definitions and implications of big-O, little-o, big-Omega, and big-Theta, as well as the conditions under which a function can be classified as big-O of another function.
  • One participant questions whether the goal is to find the lowest possible value of k such that x > k when establishing witnesses for big-O functions.
  • Another participant suggests using the limit \lim_{x\to\infty} \frac{f(x)}{x^2} = 0 as a criterion for determining big-O classification.
  • Some participants argue that both approaches to establishing big-O are valid, emphasizing that the sharpness of estimates is not crucial in big-O notation.
  • A later reply asserts that the function f(x) = 17x + 11 is not O(x^2) but rather o(x^2), indicating a misunderstanding of the definitions involved.
  • Another participant clarifies that for big-O, one must find k and C such that |x^2| <= C|17x + 11| for x > k, which they claim is impossible in this case.
  • One participant references a definition from Wikipedia, stating that f(x) = O(g(x)) requires finding a single K > 0 such that |f(x)| <= K|g(x)| for all x > x0, suggesting that f(x) could still be classified as O(x^2).
  • Another participant summarizes the definitions of big-O, big-Omega, and big-Theta, indicating a broader understanding of the relationships between these classifications.
Participants express disagreement regarding the classification of f(x) = 17x + 11 as either O(x^2) or o(x^2). Some argue for its classification as big-O, while others maintain it is little-o, indicating that the discussion remains unresolved.
There are varying interpretations of the definitions of big-O and little-o notation, leading to confusion about the conditions required for classification. The discussion highlights the importance of understanding the limits and criteria involved in these mathematical concepts.
reef
I'm not really sure which section to post this in. I'm having trouble establishing witnesses for big-O functions. Basically I'm wondering if you are looking to solve the inequality for the lowest possible value of k, such that x > k.
Here's an example of what I'm talking about.
Eg. Determine whether f(x) is O(x^2) given the function f(x)=17*x+11.
|f(x)|<=C*|g(x)| where x>k.
|(17*x+11)|
=17*x+11
<=17*x+x where x>11
=18*x
<=x^2 where x>18
Therefore, f(x) is O(x^2) with witnesses C=1 and k=18.
My friend from class tells me that there are multiple correct solutions, but the answer given to me by my instructor is as follows:
|f(x)|<=17*x^2+11*x^2 where x>1
=28*x^2
Therefore, f(x) is O(x^2) with witnesses C=28 and K=1.
Any help/insight would be appreciated. This isn't a homework thread.
Why can't you just say that [itex]\lim_{x\to\infty} \frac{f(x)}{x^2} = 0[/itex]?
Both answers are correct. It doesn't matter at all how sharp your estimates are. That's the point of big-O-notation: you only care about some limiting behaviour.
Preno's approach is equally valid, but I suspect that you haven't seen (or aren't allowed to use) this criterion.
|(17*x+11)|
=17*x+11
<=17*x+x where x>11
=18*x
<=x^2 where x>18
Well, the problem is that [itex]f(x)= 17x+ 11[/itex] is NOT O(x^2). It is "[itex]o(x^2)[/itex]" ("little o") which is what |17x+11|<= x^2 shows. But for "big O", you must also find k and C such that |x^2|<= C|17x+ 11| for x> k and that is impossible.
=28*x^2
Roughly speaking, to say that f(x)= O(g(x)) (as x goes to infinity) means that f and g have the same behaviour as x goes to infinity. And that can be determined by looking at
[tex]\lim_{x\to\infty} \frac{f(x)}{g(x)}[/tex]
as Preno suggests.
If
[tex]\lim_{x\to\infty} \frac{f(x)}{g(x}}= 0[/tex]
so that "f(x) goes to 0 faster than g(x)",
which is the case with [itex]f(x)= 17x+ 11[/itex] and [itex]g(x)= x^2[/itex], then f(x)= o(g(x)).
If that limit is some finite but non-zero number, so that "f(x) and g(x) go to 0 at the same rate", then f(x)= O(g(x)).
I don't have much experience with these little and big O things, but it seems you are using a different definition than the one on wikipedia.
It says: f(x)= O(g(x)) as x->\infty iff there exists a K>0 and x0 such that |f(x)|\leq K|x^2| for all x>x0.
So you just have to find ONE K>0 such that this holds, while for little-o you must do this for EVERY K>0. So according to this definition it seems that certainly f(x)=O(x^2).
Thanks for the replies. I've done quite a few exercises since I posted this and I think I've got it. In response to HallsofIvy, you're thinking of big-Omega which is defined as you said. There are three different types of these functions.
Big-O: f(x) is O(g(x)) if |f(x)|<=C*|g(x)| where x>k.
Big-Omega: f(x) is Ω(g(x)) if |f(x)|>=C*|g(x)| where x>k.
Big-Theta: f(x) is Θ(g(x)), if f(x) is O(g(x)) and g(x) is O(f(x)). Here you choose x>max(k1,k2).
I wish I knew how to type quantifiers and subscripts and what not. :P
  • · Replies 27 ·
