Electromagnetic fields: Eletric potential inside a non conductive sphere
The discussion centers on calculating the electric potential inside a non-conductive sphere of radius 'a' at a distance 'r' from the center, where 0 < r < a. The user is attempting to apply the equation for electric potential, specifically using the integral form of the electric field, but is confused about the limits of integration. The correct approach involves recognizing that the electric field inside the sphere is uniform and that the potential difference should be calculated from the surface to the point inside the sphere, leading to the conclusion that the first integral should equal zero.
  • Understanding of electric fields and potentials
  • Familiarity with vector calculus
  • Knowledge of integral calculus
  • Concept of non-conductive materials in electrostatics
  • Study the concept of electric potential in electrostatics
  • Learn about the properties of electric fields in non-conductive materials
  • Explore the application of line integrals in calculating electric potential
  • Review examples of electric potential calculations in spherical coordinates
Students studying electromagnetism, physics educators, and anyone interested in understanding electric potential in non-conductive materials.
GhostStudent
Hello all;
i am trying to calculate the potential, inside a non conductive sphere of radius equal to a, in a point at a distance r from the center of the sphere.
i know that:
where E and s are vectors;
and that the Eletric field inside the sphere is:
since the distance r is:
0<r<a
i changed the limits so that:
but here comes the part were i am stuck:
i found:
but the correct answer, so far, should be
which means that the first integral [
] should be equal to zero, but i can't seem to understand why
thx in advance.
p.s.:
please tell me if the images are not showing up.
It is not clear why you have two line integrals. You should use
[tex]\varphi(r)-\varphi(a)=-\int^{r}_{a}\vec{E}\cdot \vec{ds}[/tex]
i guess i was thinking more on terms of the path i should take, that's why my first integral ranges from 0 to a (size of the sphere), but since r is greater than 0 and smaller than a (because its inside the sphere, away from both the center and the surface) i changed the ranges.
dont know if i made it clear or not.
also, i was going to apply that equation, like you said, directly, but when my teacher demonstrated a similar problem in class, he also used those limits, so i guess i got a little mixed up.
thx man
  • · Replies 29 ·
