Relations between curvature and topology
The discussion centers on the relationships between curvature and topology, specifically through the lens of the Gauss-Bonnet Theorem and the Poincaré-Hopf index theorem. Participants assert that for a simple closed curve on a sphere, a vector field that is never tangent to the curve must have singular points in each region defined by the curve. Additionally, it is established that compact orientable surfaces with negative Euler characteristics must exhibit regions of positive, negative, and zero Gaussian curvature, as supported by the Gauss-Bonnet Theorem.
  • Understanding of the Gauss-Bonnet Theorem
  • Familiarity with the Poincaré-Hopf index theorem
  • Knowledge of Euler characteristics in topology
  • Basic concepts of vector fields on surfaces
  • Research the proof of the Gauss-Bonnet Theorem and its applications in topology
  • Explore the implications of the Poincaré-Hopf index theorem on vector fields
  • Study the relationship between Euler characteristics and Gaussian curvature
  • Investigate the Brower Fixed Point Theorem and its relevance to vector fields
Mathematicians, topologists, and students studying differential geometry or vector field theory will benefit from this discussion, particularly those interested in the interplay between curvature and topology.
joseph0086
Hello, all, the most important results that I know in this topic is the Gauss-Bonnet Theorem (and hence the classification of compact orientable surfaces) and also the Poincare-Hopf index theorem.
But there are still some fundamental problems I don't understand.
For example, is the following problem true?
Let C be a simple closed curve on a sphere. Let v be a vector field on it such that v is never tangent to C. Is it true that each of the regions determined by C contains at least one singular point of v.
I feel it is true, but I don't know how to prove it...
Moreover, it is intuitivlely clear that all compact orientable surfaces with negative euler characteristics have some regions which have Gaussian curvatures positive, negative and zero. The fact that it has regions that have -ve curvature is obvious by Gauss-Bonnet. But how to show mathematically that it must have some regions that have positive curvature? (In other words, my question is: Show that compact orientable surface has negative curvature at all points.)
I learned from a textbook that for all such surfaces with -ve Euler characteristics, then two geodesics which start from the same point won't meet again. (Easy to show by Gauss-Bonnet), I don't know if it is related to my question..
Hope somebody here can tell me his understanding.. Thanks a lot.
If the vector field always points into or out of the disc shaped region then it must have a singularity in the interior. I am sorry that I can not quickly give you a picture but here is an attempt at a proof.
Imagine a disk in the plane with a vector field on it that always points outwards along its bounding circle. If the vector field has no singularity then it can be normalized to have length 1 i.e. it can be turned into a map from the disk into the unit circle. This means that the map restricted to the boundary is null homotopic. But if it always points outwards then it can be smoothly deformed into the field that is perpendicular to the boundary and this map is not null homotopic.
It occurs to me that this is really the Brower Fixed Point theorem in disguise but not sure. It would be fun to think about this if you like.
I would love to see a more intuitive proof.
In 3 space every surface must have a region of positive Gauss curvature. This was proved by Hilbert and is easy to see. Try a proof.
However, a surface of negative Euler characteristic can be given a metric of constant negative Gauss curvature. I think the proof is that all such surfaces are covered by the unit disk in the plane under the action of a group of Mobius transformations that preserve the Poincare metrx which has curvature -1.
The torus has Euler characteristic zero so must have equal total positive and negative curvature. The torus can be given a metric of everywhere zero Gauss curvature. this because it is covered by the action of a lattice on the plane. An explicit realization of the flat torus is
(x,y) -> (sinx,cosx,siny,cosy) but this is in four dimensions.
Hello there, great question! I am not an expert in this topic, but I will try to offer some insight based on my understanding.
Firstly, to address your question about the regions determined by C containing at least one singular point of v, I believe this is true. This is because if v is never tangent to C, it means that v is always pointing in a direction perpendicular to C. This would imply that v is always pointing towards or away from the interior of the region, and therefore there must be a point where v becomes singular (either a point of zero magnitude or a point where it changes direction). However, I am not sure how to prove this mathematically.
As for your second question, it is indeed true that compact orientable surfaces with negative Euler characteristics must have regions with both positive and negative Gaussian curvatures. This can be shown using the Gauss-Bonnet theorem, which relates the total Gaussian curvature of a surface to its Euler characteristics. If the Euler characteristics is negative, then the total Gaussian curvature must also be negative, which means that there must be regions with both positive and negative Gaussian curvatures.
Regarding your question about geodesics not meeting again, I am not sure how it is related to the previous question. However, it is an interesting fact that for surfaces with negative Euler characteristics, two geodesics starting from the same point will not meet again. This can be shown using the Gauss-Bonnet theorem as well.
I hope this helps in your understanding. Maybe someone with more expertise can chime in and provide a more thorough explanation. Keep exploring and learning!
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 108 ·
13K
  • · Replies 21 ·
9K
