How to Calculate Electron-Degeneracy Pressure in a White Dwarf?
  • Thread starter Thread starter ajclarke
    Structure
The discussion focuses on calculating Electron-Degeneracy Pressure in a white dwarf, specifically as a fraction of total pressure. The calculated Electron-Degeneracy Pressure is 3.383 × 1061 Pa. The user seeks assistance in calculating Thermal Pressure using density and temperature, applying the equation P = (ρkT/μ) with μ set to 4/3 for pure helium, resulting in a value of 6.213 × 10-10 Pa. The user expresses concern that this value appears significantly smaller than expected, given the approximate atmospheric pressure of 100 kPa.
  • Understanding of Electron-Degeneracy Pressure calculations
  • Familiarity with thermal pressure equations
  • Knowledge of astrophysical concepts related to white dwarfs
  • Proficiency in using constants such as Boltzmann's constant (k) and atomic mass units
  • Research the derivation of Electron-Degeneracy Pressure equations
  • Learn about the relationship between density, temperature, and thermal pressure in astrophysical contexts
  • Investigate the implications of different values of μ in thermal pressure calculations
  • Explore numerical methods for solving equations in astrophysics
Astrophysicists, students studying stellar evolution, and anyone involved in theoretical physics related to white dwarf characteristics.
ajclarke
Have to calculate the Electron-Degeneracy Pressure as a fraction of the total pressure in a white dwarf. Given Density and Temperature.
[tex](\frac{1}{5m_{e}}) (\frac{3h^3}{8 \pi})^{2/3} (\frac{\rho}{\mu_{e}M_{H}})^{5/3}[/tex]
I have calculated the Electron-Degeneracy Pressure as:
[tex]3.383 \times 10^{61} \textrm{Pa}[/tex]
Now I need to calculate the Thermal Pressure using the density and temperature so I can find this fraction but I can't for the life of me think how to do it.
Cheers
Shameless bump, could really use some help with this.
I have tried a bit more myself. Using:
[tex]P=\frac{\rho k T}{\mu} = \frac{1.3807 /times 10^{-23} \times 3 \times 10^6 \times 2 \times 10^7 \times 3}{4}=6.213 \times 10^{-10}[/tex]
Using values given above, and taking mu as being 4/3 for pure helium. However this seems very very small, given that atm P = 100KPa (approx)
ALso if I then finish the question of the fractional degenerate pressure, being such a large number gives it as 1.
Thanks in advance.
Last ditch attempt before It has to be handed in.
  • · Replies 23 ·
