| New Reply |
Installing Modnum with Scicoslab |
Share Thread |
| Apr18-11, 09:52 AM | #1 |
I am having problems installing Modnum for use with Scicoslab.
I am using Ubuntu 10.4 LTS 64 bit for AMD processor. First I tried Scicoslab 4.4.1 (scicoslab-gtk_4.4.1-1_amd64.maverick.deb) and Modnum 4.2.2. When I run Scicoslab, it complains that Modnum was compiled with Scicoslab 4.4 beta 7. So, I remove 4.4.1 and install 4.4 beta 7. Now I get this message when I launch scicoslab: Startup execution: loading initial environment ... Search Scilab version ... Version of ScicosLab is : 4.4b7 Version of Scicos is : scicos4.4 /home/skippy/modnum_422//interf/scicoslab/../../src/libmodnum_lib.so: wrong ELF class: ELFCLASS32 "/../../src/libmodnum_lib.so") !--error 236 link: the shared archive was not loaded at line 55 of exec file called by : exec(MODNUM+"/interf/scicoslab/loader.sce"); at line 16 of exec file called by : exec(startup,-1);mclose(startup) at line 272 of exec file called by : exec('SCI/scilab.star',-1);;quit So I try "./configure --with-scisrc=/usr/lib64/scicoslab-gtk-4.4b7" followed by "make all" gives pages of error messages. Can you suggest which version of Scicoslab and which version of Modnum will be compatible? Any help or suggestions would be greatly appreciated. Skippy PS There is a installation support email address on the Modnum download page but it is dead. |
| Apr21-11, 03:03 PM | #2 |
Hi Skippy,
I just installed Modnum to Scicoslab 4.4.1 under Debian 'squeeze' this afternoon. here's what I did: - Tried to run the binary of Modnum 4.2.2 and got the same complaint as you did. - Downloaded the source package instead and ran "exec ('builder.sce');) - I had to install a few packages (and recursive dependencies) over and above what I already had (your mileage may vary): libgtk2.0-dev libvte-dev libwebkit-dev It doesn't install to the scicoslab directories, but everything compiles and works beautifully. Give it a go. Cheers, The Plumber |
| Apr21-11, 03:39 PM | #3 |
More's the point:
Installing modnum into the scicoslab directories so that it loads automatically is done thus: - Copy the modnum directory tree, as built using the instructions above, into (in my case): /usr/lib/scicoslab-gtk-4.4.1/contrib/ (you end up with the directory /usr/lib/scicoslab-gtk-4.4.1/contrib/modnum, for example) - Edit /usr/lib/scicoslab-gtk-4.4.1/contrib/loader.sce to add: exec(SCI+'/contrib/modnum/loader.sce'); Now scicoslab/scicos loads your shiny new modnum blocks, palettes, help, etc. Cheers, Pb |
| Apr21-11, 08:21 PM | #4 |
Many thanks Plumber
| New Reply |
Similar discussions for: Installing Modnum with Scicoslab
| Installing CompHEP on Mac OS X 10.5 | Math & Science Software | 1 | ||
| installing new HD | Computers | 6 | ||
| Installing Windows on a new HDD | Computers | 3 | ||
| Installing more RAM than.... | Computing & Technology | 10 | ||
