How to Design an RTL Circuit with Basic Logic Components?
This discussion focuses on designing a Register Transfer Level (RTL) circuit using basic logic components such as inverter gates, NAND gates, 4-input multiplexers, D flip-flops, and a 4-bit adder. The circuit must perform operations including addition, incrementing, arithmetic left shift, 2's complement, bit-wise complement, and loading a value into a register. The key to constructing the circuit lies in sequentially processing each operation, where the output of one step serves as the input for the next. A systematic approach using truth tables is recommended for clarity in design.
  • Understanding of RTL circuit design principles
  • Familiarity with basic logic gates (inverters, NAND gates)
  • Knowledge of D flip-flops and their operation
  • Experience with multiplexers and their configuration
  • Research how to implement a 4-bit adder circuit
  • Learn about the operation and design of D flip-flops
  • Study truth table creation for combinational logic circuits
  • Explore the design and application of multiplexers in circuit design
Electronics students, circuit designers, and engineers involved in digital logic design and RTL circuit implementation will benefit from this discussion.
mathrocks
I have to design a circuit that does the following operations:
Add L to w w<--w+L
Increment w w<--w+1
arithimetic left shift w w<--arithemetic left shift of w
2's complement of w w<--w'+1
Bit-wise complement of w w<--w'
load L into w w<--L
How do I go about even starting to make this circuit using only inverter gates, NAND gates, 4 input multiplexers, D flip flops, and a 4bit adder.
There has to be some easy way through a simple truth table. My teacher likes to just draw the entire circuit out, but I can't see it that way.
Thank you!
There are several steps in the specifications. Just take them one step at a time in order, and couple the output of step 1 as the input to step 2. Presumably, the course has taught you how to do all those individual steps.
