Proving that a set is countable
  • Thread starter Thread starter georgetown13
    Set
The problem involves proving that the sets Fj, defined as the set of ordered j-tuples with entries from a countable set U, are countable for j=1, 2, 3, ... Participants are exploring the implications of the definition of Fj and its relationship to the countability of U.
  • Some participants question the nature of the set Fj and whether it is a subset of U. Others discuss the need to prove that finite subsets of a countable set are also countable.
  • There is a suggestion of using induction to prove the countability of Fj, although some participants express confusion about the clarity of the original question.
  • One participant clarifies that Fj represents ordered j-tuples and emphasizes that it is not a subset of U, providing an example with the real numbers.
The discussion is ongoing, with participants providing clarifications and exploring different interpretations of the problem. Some guidance has been offered regarding the nature of Fj and the potential use of induction, but there is still uncertainty about the specific proof required.
Participants are grappling with the definitions involved and the implications of countability, as well as the assumptions that may need to be checked in the proof process.
georgetown13
Let U be a countable set. For j=1, 2, 3, ... define
Fj= {(x1, x2, ... , xj): xi [tex]\in[/tex] U for all i=1,2,...,j}
Prove that j=1,2,3,...,Fj is countable.
I'm having trouble understanding what the set Fj contains.
F1={x1}
F2={x1, x2}
And so on...
But as xi for all i=1,2,3,...,j is in U, does that mean Fj is a subset of U?
Does this mean that I have to prove that if a set is countable, its subset is countable?
If so, how would I go about doing that?
Please help! I would greatly appreciate it. I'm having a hard time just understanding the question at all.
Do I have to use induction for this proof?
edit: oops, misunderstood the the definition of Fj (the post from hallsofivy below is correct), the following comment does not make sense. :)
your question is not clear. what set are you trying to show is countable?
if you are trying to show that for all j, Fj is countable, then that makes sense. but then you would showing that any finite subset of a countable set is also countable, and that is not impressive because any finite set is countable.
so, i am still not quite clear what you want to show.
[itex]F_j[/itex] is the set of "ordered j-tuples" with entries in U. No, [itex]F_j[/itex] is NOT a subset of U. For example, it we take U= R, then [itex]F_2= R\times R[/itex]. R if we think of R as the number line, then [itex]F_2[/itex] is represented by the plane, all points of the form (x, y). (Yes, I know R is not countable. My point is to explain what [itex]F_j[/itex] is.)
If you already have the theorem "If A and B are countable, then [itex]A\times B[/itex] is countable" this is simple- use induction on j.
If not- prove it! If A is countable, we can list its members: [itex]a_1, a_2, a_3, \cdot\cdot\cdot[/itex]. If B is countable, we can list its members: [itex]b_1, b_2, b_3, \cdot\cdot\cdot[/itex]. Now, imagine writing the members of A, horizontally, along the top of a sheet of paper, and B, vertically, along the left side. Where the ith row meets the jth column is the pair [itex](a_j, b_i)[/itex]. We can count all such members by "zigzagging" through that array: [itex](a_1, b_1)[/itex][itex], (a_2, b_1),[/itex][itex](a_1, b_2), (a_1,b_3), (a_2, b_2), (a_3, b_1), (a_4, b_1),\cdot\cdot\cdot)[/itex].
  • · Replies 18 ·
  • · Replies 16 ·
