I(n) = ∫sin^n (x) dx (integration by parts)
The discussion revolves around the integration of the function I(n) = ∫ sin^n(x) dx, specifically using integration by parts to express it in terms of I(n-2). Participants also explore the evaluation of a definite integral involving sin^(-4)(x).
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the integration by parts approach and the resulting expression for I(n). There are questions about the correct application of values for n and the use of substitution in the context of definite integrals.
Some participants have provided guidance on the correct formulation of I(n) and the evaluation of the definite integral. There is an acknowledgment of mistakes in the application of substitution and the need for clarification on the integral process.
Participants note confusion regarding the limits of integration and the application of the reduction formula. There is also mention of using external tools for verification, which raises questions about the integral process itself.
vmr101
i)Use integration by parts to express:
I(n) = ∫ sin^n (x) dx
in terms of I(n-2).
ii) Hence show that ∫(π/2 for top, π/4 for bottom) 1/[sin^4 (x)] dx = 4/3
Reduction Formula and Trig Identity [sin²(x) + cos²(x) = 1]
π = pi
i) Integrate by parts with
u = sin^(n-1)(x) => du = (n-1)·cos(x)·sin^(n-2)(x)
dv = sin(x) => v = -cos(x)
I ended up with:
∫ sin^n(x) dx
= -(1/n)·cos(x)·sin^(n-1)(x) + [(n-1)/n]· ∫ sin^(n-2)(x) dx
ii) Would this be integration by substitution and parts?
= log{ -(1/4)·cos(x)·sin^(3)(x) + [3/4]· ∫ sin^(2)(x) dx }
=> log{ -(1/4)·cos(x)·sin^(3)(x) + [3/4]·(-(1/2)·cos(x)·sin(x) + [1/2]) }
I pushed the numbers through but got this wrong, where did i go wrong?
Thanks in advance.
You correctly found
[tex]I(n) = -\frac{1}{n}\cos x\sin^{n-1} x + \frac{n-1}{n} I(n-2)[/tex]
Now you're asked to evaluate
[tex]\left \int_{\pi/4}^{\pi/2} \sin^{-4} x \, dx = I(-4)\right\rvert_{x=\pi/4}^{x=\pi/2}[/tex]
But it looks like you used n=4. Try a different value of n. Also, where did the log come from?
Of course! Thanks.
I don't know why, but i used substitution to change everything under the 1 to u, then used the integral of 1/u is log, then replaced u back in, then used the 4.
I knew i was doing something wrong.
Thanks for the help! Its much appreciated.
I put int 1/sin^4 into wolframa alpha website and got
-(1/3)*cot(x)(csc^2(x)+2)
I then put pi/2 and pi/4 and got the answer 4/3.
Is anyone able to explain the integral process for:
int 1/sin^4(x)
Thanks
You have found:
And we know:
[tex]I(-2)=\int \frac{dx}{sin^2(x)}=-cot(x)+C[/tex]
Then for finding I(-4) you have to use the formula for n=-2.
