Elevator problem with safety rails, spring, and a snapping cable->
The discussion revolves around a physics problem involving an elevator that falls and compresses a spring after its cable snaps. The problem includes aspects of mechanics, specifically dealing with forces, energy conservation, and kinematics. Participants are tasked with calculating the speed of the elevator just before it hits the spring, the maximum compression of the spring, and the subsequent motion of the elevator cab.
  • Mixed
  • Participants explore kinematic equations to find the speed of the cab before it hits the spring, questioning the effects of friction on acceleration and velocity.
  • There are discussions about calculating net forces acting on the cab, including gravitational and frictional forces, and how to derive acceleration from these forces.
  • Some participants attempt to apply energy conservation principles to find the maximum compression of the spring, while others raise concerns about accounting for energy lost due to friction.
  • Questions arise regarding the relevance of distances used in calculations, particularly whether to include the distance fallen before reaching the spring in energy equations.
The discussion is ongoing, with participants actively engaging in problem-solving and clarifying concepts. Some have made progress in calculating values, while others are still questioning their methods and results. Guidance has been provided regarding the correct application of forces and energy principles, but no consensus has been reached on the final answers.
Participants are working under the constraints of a homework assignment with a deadline, which may influence their willingness to explore all parts of the problem thoroughly. There is an emphasis on understanding the role of friction and the correct application of energy conservation in the context of the problem.
VinnyCee
Elevator problem with safety rails, spring, and a snapping cable--->
The cable of an 1800 kg elevator snaps while it is 3.7 meters above a spring with constant of k = 0.15 MN/m. Also, a safety guide rail device provides a 4.4 kN frictional force against the fall for the duration of the fall.
a) What is speed of cab just before hitting the spring?
b) What is the maximum distance x that the spring is compressed (frictional force still applies during the compression of the spring)?
c) How far will the cab bounce back up the shaft?
d) What is the total distance the cab will move before coming back to rest?
Help, I have been trying to figure this out for 3 hours!
what have you done?
I am not really sure if this is correct for the first part of the problem (a):
I used the equation [itex]v^2 = v^2_0 + 2a(x-x_0)[/itex] and used [itex]0[/itex] for initial velocity and [itex]9.8 m/s^2[/itex] for a and [itex]3.7 m[/itex] for [itex]x-x_0[/itex] (also displacement d)
Substituting, I get: [itex]v^2 = 19.6 m / s^2 * 3.7 m = 72.52 m^2 / s^2[/itex] and then [itex]v = 8.52 m / s[/itex], when the cab hits the spring, right? Or am I going about this all wrong?
I think that I am forgetting the frictional force acting on the cab in a constant manner opposing it's fall, it says that this force is 4400 N, how would I "subtract" thhis from the 8.52 m / s?
Nothing wrong with using kinematics to find the speed. But you'd better use the correct acceleration. The acceleration would be 9.8 m/s^2 if gravity were the only force acting on the cab. But friction acts. So find the net force on the cab, then use Newton's 2nd law to find the acceleration.
How do I find the net force then?
You tell me. What forces act on the elevator cab?
The force of gravity, [itex]mg[/itex], which is [tex]1800 kg * 9.8 m / s^2 = 17640 N[/tex]. Then the force of the friction, [tex]f_k[/tex], which is [tex]ma[/tex], which I know [tex]mass = 1800 kg[/tex], but I don't know acceleration.
Good.
The force of friction is given. It is not equal to ma: Newton's 2nd law says that the net force on an object equals ma.
Here's how to think of it. There are two forces acting on the cab:
(1) the weight, acting down (you calculated this)
(2) the friction, acting up (this is given)
Find the net force by adding these two forces (direction counts--forces are vectors). Then figure out the acceleration.
Is the net force on the cab then [tex]17640 N - 4400 N = 13240 N[/tex]?
Right! That's the net force, which acts down. Use that to find the acceleration.
The net acceleration of the system is then [tex]13240 N / 1800 kg = 7.35 m / s^2[/tex]? How do I use this to find the velocity after falling [tex]3.7 m[/tex]?
Does the velocity come from the same equation [itex]v^2 = v^2_0 + 2a(x-x_0)[/itex]? If so, I get [tex]v^2 = (0)^2 + 2(7.35 m / s^2)(3.7 m)[/tex]
And then: [tex]v = \sqrt{54.39} = 7.37 m / s[/tex] < ---- Is this correct?
Looks good to me.
About part b), I have this so far:
[tex]0 - \frac{1}{2} m v^2_i = m g (d) - \frac{1}{2} k (d)^2[/tex]
[tex]-\frac{1}{2} (1800 kg)(7.4 m / s)^2 = (1800 kg)(9.8 m / s^2) (x_{max}) - \frac{1}{2}(150000 N / m)(x_{max})^2[/tex]
Eventually I calculate that the [tex]x_{max} = -0.70 m[/tex] or [tex]x_{max} = 0.94 m[/tex], in which case I would choose [tex]0.94 m[/tex], right? Does this all look correct or am I way off again?
energy lost to friction
You forgot to account for the energy lost to friction. (Mechanical energy gets transformed to heat.) The initial mechanical energy is KE + Gravitational PE; the final is Spring PE. The difference is the work done against friction.
How would I go about accounting for this lost energy due to heat? What formulas would I use?
the energy due to friction would be the magnitude of the frictional forces times the distance it moved along (parallel to the motion)
Would it then be:
[tex]-\frac{1}{2} (1800 kg)(7.4 m / s)^2 = (1800 kg)(9.8 m / s^2) (x_{max}) - \frac{1}{2}(150000 N / m)(x_{max})^2 - (4400 N)(3.7 m)[/tex]?
Then I get: [tex]x_{max} = 0.79 m[/tex], does that sound right?
Why are you using 3.7m? That was the distance used in part a; it's not relevant here. For part b, over what distance does friction act?
3.7 m is the distance the elevator cab falls before reaching the spring, then the spring compresses an additional [tex]x_{max}[/tex] m and then the total distance would be [tex](3.7 + x_{max}) m[/tex]?
Is this right:
[tex]-\frac{1}{2} (1800 kg)(7.4 m / s)^2 = (1800 kg)(9.8 m / s^2) (x_{max}) - \frac{1}{2}(150000 N / m)(x_{max})^2 - (4400 N)(3.7 + x_{max})[/tex]
[tex]x = 0.83 m[/tex]? Or am I eternally doomed to be a physics retard?
In your analysis for part b you are comparing energy at two points:
(1) where the cab first reaches the spring (you calculated its speed at that point)
(2) where the spring is maximally compressed
In moving from point 1 to point 2, the cab moves a distance of [itex]x_{max}[/itex]. The 3.7 m that the cab moved prior to reaching point 1 is no longer relevant (at least in this analysis).
OK, so I drop the whole 3.7 m thing because it was traversed before the compression?
How about this?
[tex]-\frac{1}{2} (1800 kg)(7.4 m / s)^2 = (1800 kg)(9.8 m / s^2) (x_{max}) - \frac{1}{2}(150000 N / m)(x_{max})^2 - (4400 N)[/tex]
So [tex]x_{max} = 0.9 m[/tex]?
Right.
Check the last term in your energy equation.
Check the last term? Do you mean the [tex]4400 N[/tex] part? I thought that had to be included also, because the friction still acts while the spring is compressed? So, [tex]0.9 m[/tex] is the correct answer for part b?
Right. So shouldn't it be multiplied by some distance?
Is it multiplied by the unknown distance [tex]x_{max}[/tex]?
The calcualtion still comes out to be [tex]x_{max} = 0.90 m[/tex], do I finally have this part figured?
Yes, as that term represents the work done against friction.
Thank you very much for your help! I am not even going to try and do the last two parts, this assignment is due today anyways. Can you recommend any really good sites for physics? One's with many explanations and sample problems (other than here of course!)?
  • · Replies 47 ·
9K
14K
