Why does the LPG cylinder has to be two parts welded together
  • Thread starter Thread starter pbaero222
    Cylinder parts
The discussion centers around the structural design of LPG cylinders, specifically the reasoning behind them being constructed from two welded parts. Participants explore the implications of this design choice in terms of safety, manufacturing processes, and alternative methods.
  • One participant notes that the shape of the cylinder cannot be extruded, necessitating a join, and suggests that having the join in the center is beneficial for structural integrity.
  • Another participant argues that the ends of a pressurized cylinder are the weak points, and having them as a single piece of metal enhances safety and structural design.
  • A different viewpoint is presented, stating that welding the ends is not strictly necessary and is primarily a cost-effective method. This participant cites larger tanks that use welded ends and mentions oxygen cylinders that do not have welds yet can withstand high pressures.
  • There is a mention of the complexity involved in assembling different types of gas cylinders, indicating that design choices may vary based on functionality.
Participants express differing opinions on whether welding the ends of LPG cylinders is essential or merely a cost-effective choice. The discussion remains unresolved regarding the necessity of this design feature.
Participants reference various types of gas cylinders and their construction methods, indicating that the discussion may depend on specific applications and definitions of safety and structural integrity.
Engineering students, professionals in manufacturing and safety design, and individuals interested in the structural integrity of pressurized vessels may find this discussion relevant.
pbaero222
Am a second year be student.While in a discussion in class my professor posed this question to us"Why does the LPG cylinder has to be two parts welded together".I tried searching it in net but coudn't kinda get the answer so can somebody explain it to me...
And since am newbie to the engineering terms pls make the explanation easy and simple...
Well firstly, you can't extrude that shape, there must be at least one join (which there is).
Which then leads to why in the center?
Well the weak points on a pressurised cylinder (as with aircraft) are the ends. So by ensuring the ends are one complete piece of metal (no joins with the main body) you get the best and simplest structural design for presurisation.
Thank you jared james...!
I don't think the two ends NEED to be welded together. It is just a cost effective way of doing it that is perfectly safe. It isn't that there is no other way of building them. Larger tanks (500 gal) have each end welded on. Consider an oxygen cylinder for an oxy-acetyline torch. No welds anywhere. When full are at around or above 2000 PSI. The acetyline tank however is assembled like the propane cylinder. There is an insert inside an acetyline tank that the gas is released out of when used. So it would be difficult to assemble one of them any other way.
