Register to reply
What is the derivation for decrease in g with depth?
by Quantum Mind
Tags: 'g', depth, derivation, variation
Share this thread:
Quantum Mind
#1
Apr22-11, 02:24 AM
P: 72
We know that 'g' decreases with height and the derivation for the formula is straight enough, but how is the formula for decrease of 'g' with depth derived?
3. The attempt at a solution
If an object is taken to a height 'h' above the surface of the earth and assuming the radius of the earth as 'R', then acceleration due to gravity at a height 'h' is given by the formula
gh = GM/(R+h)2
After adding R2 to both denominator and numerator, we get the formula
gh = g[R/(R+h)]2
However, the same formula will not work for depth because if (R-h) is substituted for (R+h) in the above formula, then the value of 'gh' will actually increase, which is not the case. I know that the correct formula to be used here is gh = g[(R-h)/R], but how is that derived ? I know this is pretty basic but I am not able to get the hang of it.
Would appreciate if somebody can please explain.
Phys.Org News Partner Science news on Phys.org
Security CTO to detail Android Fake ID flaw at Black Hat
Huge waves measured for first time in Arctic Ocean
Mysterious molecules in space
kewljerk
#2
Apr22-11, 03:11 AM
P: 4
It is somewhat similar as we derive electric field inside a dielectric sphere.
=>1st approach
use gauss law for finding out the electric field inside a dielectric sphere. it will come to be Qx/4*pi*epsilon*R^3
simply replace 4(pi)esilon by G and Q by M-mass of earth, you will get the formula of g inside the earth.Mind it here x is distance from the center.
=>2nd approach
g=GM/r^2 for a spherical shell where r=distance from the center
so, here take a spherical shell at a distance x from center, so g due to that shell=G(p*4pi*r^2)dr/x^2
where p=density of the earth=M/(4/3&pi*R^3)
integrate above differential equation from 0 to x and put the value of p. If you want answer in terms of distance from the surface of the earth simply replace x by R-h.
ashishsinghal
#3
Apr22-11, 03:39 AM
P: 460
Have you read gauss law? That will help you understand it.
AlexChandler
#4
Apr22-11, 05:46 PM
AlexChandler's Avatar
P: 283
Yes the basic idea is this: picture the point where you want to calculate g. Now imagine a sphere with the center of the earth as its center, that has this point on its surface. Gauss' law says that only the mass contained within this sphere counts toward the gravitational field at that point. So really we can find the g value here simply as
[tex] \vec g = - \frac{V'}{V} \frac{GM}{r^2} \hat r [/tex]
Where V' is the volume of the imaginary sphere and V is the volume of the earth. M is the mass of the entire earth, and r is the distance from the center of the earth to the point in question.
Of course this relies on the assumption that the earth is uniform in its density which is not quite true, but this is a decent approximation.
And actually this is just
[tex] \vec g = - \frac{r^3}{R^3} \frac{GM}{r^2} \hat r [/tex]
where R is the radius of the earth. or we can say
[tex] \vec g = - \frac{GMr}{R^3} \hat r [/tex]
This is quite interesting because if we were to drill a hole all the way through the earth and drop an object in, it would feel a restoring force proportional to the distance r from the center, which would act to make the object oscillate exactly like a mass and spring system.
Comparing to the mass spring system we see the object will have a period:
[tex] T = 2 \pi \sqrt{ \frac{R^3}{GM} } [/tex]
AlexChandler
#5
Apr22-11, 06:00 PM
P: 283
Just to clarify, I arrived at the first equation by considering the density of the earth
[tex] \rho = M/V [/tex]
and then the mass contained within the sphere is
[tex] M' = \rho V' [/tex]
so we have
[tex] \vec g = - \frac{GM'}{r^2} \hat r [/tex]
AlexChandler
#6
Apr22-11, 06:13 PM
P: 283
And if you are curious, here is gauss' law:
[tex] \oint_S \vec g \cdot \hat n dA = - 4 \pi G \oint_V \rho dV [/tex]
Does this make much sense to you? I can elaborate if you like.
AlexChandler
#7
Apr22-11, 06:15 PM
P: 283
Or alternatively (in differential form):
[tex] \nabla \cdot \vec g = - 4 \pi \rho G [/tex]
Quantum Mind
#8
Apr24-11, 09:43 PM
P: 72
Thanks all. I think I am beginning to understand. But can I have the derivation for gh = [(R-h)/R] please ?
AlexChandler
#9
Apr24-11, 10:00 PM
P: 283
Quote Quote by Quantum Mind View Post
What is this formula for? I dont think its right... the left side has dimensions of acceleration and the right side is dimensionless.
AlexChandler
#10
Apr24-11, 10:11 PM
P: 283
Oh i see what you meant.
Yes it is as follows. As you see, a result from the equations above is,
Following your convention let us call the gravitation field vector at this location g sub h
Then we can write that the magnitude of g sub h is
[tex] g_h = \frac{GM'}{(R-h)^2} [/tex]
where i have substituted r= R-h
Now we also have, as explained above,
[tex] M' = \frac{r^3}{R^3} M [/tex]
So we have
[tex] g_h = \frac{GM}{R^2} \frac{r^3}{R} \frac{1}{r^2} [/tex]
and therefore, substituting r=R-h and g=GM/R^2
[tex] g_h = g \frac{R-h}{R} [/tex]
Quantum Mind
#11
Apr24-11, 11:33 PM
P: 72
Thank You, I get it now.
Register to reply
Related Discussions
HCl + Mg = decrease in pH? Why? Chemistry 9
Entropy decrease General Physics 6
Setup help needed:apparent depth vs. actual depth Introductory Physics Homework 17
Actual Depth and Apparent Depth Introductory Physics Homework 19
Loc Max, Min, increase & decrease! General Math 8
