Calculating Reaction Force in High Volume Air Blow through Piping Circuits
This discussion focuses on calculating the reaction force generated by high-volume air blow through piping circuits. The key formula for determining the reaction force is based on the rate of change of momentum of the escaping gas. Participants emphasize the need for a detailed method to calculate this force, suggesting that the reaction force can be approximated using the formula: Reaction Force = Pipe Area x Average Blow Pressure x 100. Understanding the specific variables involved is crucial for accurate calculations.
  • Fluid dynamics principles
  • Basic physics of momentum
  • Piping system design
  • Pressure measurement techniques
  • Research fluid dynamics equations related to momentum and force
  • Learn about pressure drop calculations in piping systems
  • Explore the effects of pipe diameter on flow rates
  • Study the application of Bernoulli's principle in air flow systems
Mechanical engineers, process engineers, and anyone involved in the design and analysis of pneumatic systems will benefit from this discussion.
commissioning
When Executing an air blow through a circuit of piping at high volumes and resonable pressures. How would you calculate the reaction force that the piping circuit will generate by the open end exit blow of air? Need a detailed method of how to calculate and what the numbers used represent and mean.
Reaction force = rate of change of the momentum of the escaping gas.
I know that but how do I calculate. For example. Pipe area x average blow pressure x 100? I mean how?
  • · Replies 20 ·
12K
  • · Replies 33 ·
  • · Replies 45 ·
