New Reply
Simple question about object submerged in a fluid (fluid Mechanics)
Share Thread
Apr22-11, 07:30 AM   #1
If an object like a sphere is submerged in a fluid and held in place by a rope, does the pressure are the top and the bottom of the sphere have anything to do with the weight/density/geometery of the sphere? or is it simply a case of using the hydrostatic equation for the pressure at the top and the bottom of the object?
In gerneral does pressure in a fluid relate to the properties of objects which may be submerged in it?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Apr22-11, 09:21 AM   #2
Quote by aero&astro View Post
Not affected at all. You could equally have an arbitrarily shaped container. The hydrostatic pressure is still just a function of the vertical depth, even if you have to go round corners to get the measurement point.
Of course putting an object into a container of fluid will increase the pressure by raising the height of the free surface, but it's still the same equation of p = density * g * depth.
New Reply
Tags
fluid mechanics, fluids, fluids at rest, pressure under water, upthrust
Similar discussions for: Simple question about object submerged in a fluid (fluid Mechanics)
Thread Forum Replies
simple challenging fluid mechanics question(buoyancy) Mechanical Engineering 8
Finding Mass of an Object [Fluid Mechanics] Introductory Physics Homework 2
Simple Fluid Mechanics-differential manometer question. Please :) Engineering, Comp Sci, & Technology Homework 2
Archimedes' Principle - Submerged object in a fluid Introductory Physics Homework 0
Fluid Mechanics of an object General Engineering 4
