Nuclear Reactor In Ga. Shuts Down Abruptly
The discussion revolves around the abrupt shutdown of a nuclear reactor at the Vogtle facility in Georgia. Participants are seeking information about the reactor's status, the cause of the shutdown, and the implications of the event, with references to regulatory notifications and operational procedures.
  • Some participants inquire about the current status of the reactor following its automatic trip from 100% power.
  • There is a suggestion that the incident may not be serious, with one participant proposing it could be a spurious trip.
  • Details from the NRC indicate that the reactor trip was automatic, with all control rods fully inserted and the plant stable during the investigation.
  • One participant mentions that reactor trips are not unusual and lists potential causes such as lightning strikes and tin whiskers.
  • Another participant suggests that using lead-tin solder could mitigate issues related to tin whiskers in nuclear power plant equipment.
  • A later reply indicates that a defective breaker is believed to be the cause of the trip, and mentions that the plant has returned to operation at full power.
Participants express varying degrees of concern regarding the incident, with some viewing it as a standard operational issue while others highlight the need for investigation. There is no consensus on the implications of the reactor trip or the specific causes, as multiple hypotheses are presented.
Participants reference regulatory notifications and operational protocols, but there are unresolved questions regarding the exact cause of the reactor trip and the potential impact of the event.
javadave
http://www.cbsatlanta.com/news/27633540/detail.html?utm_source=twitterfeed&utm_medium=twitter
Does anybody have any further information on current status of this reactor in GA?
this cannot be good news.
http://www.nrc.gov/reading-rm/doc-collections/event-status/event/2011/20110421en.html
Power Reactor Event Number: 46772
Facility: VOGTLE
Region: 2 State: GA
Unit: [1] [ ] [ ]
RX Type: [1] W-4-LP,[2] W-4-LP
NRC Notified By: BILL DUNN
HQ OPS Officer: MARK ABRAMOVITZ Notification Date: 04/20/2011
Notification Time: 20:45 [ET]
Event Date: 04/20/2011
Event Time: 17:34 [EDT]
Last Update Date: 04/20/2011
Emergency Class: NON EMERGENCY
10 CFR Section:
50.72(b)(2)(iv)(B) - RPS ACTUATION - CRITICAL
50.72(b)(3)(iv)(A) - VALID SPECIF SYS ACTUATION
Person (Organization):
JONATHAN BARTLEY (R2DO)
Unit SCRAM Code RX CRIT Initial PWR Initial RX Mode Current PWR Current RX Mode
1 A/R Y 100 Power Operation 0 Hot Standby
Event Text
AUTOMATIC REACTOR TRIP
"At 1734 EDT, [Vogtle] unit one automatically tripped from 100% power. No significant activities were in progress that should have challenged the Reactor Protection System. All control rods fully inserted. AFW system actuated as expected on S/G Lo-Lo-Level and AMSAC [ATWS Mitigation System Actuation]. System responses allowed for an uncomplicated reactor trip response. Plant is stable and will remain in Mode 3 during cause investigation.
"Cause of the reactor trip is under investigation."
The plant is in its normal shutdown electrical lineup. Decay heat is being sent to the main condenser through the turbine bypass valves. The steam generators are being fed from auxiliary feedwater. There was no effect on unit two.
The licensee informed the NRC Resident Inspector.
NUCENG said:
[URL]http://www.nrc.gov/reading-rm/doc-collections/event-status/event/2011/20110421en.html
Facility: VOGTLE
Region: 2 State: GA
Unit: [1] [ ] [ ]
10 CFR Section:
Event Text
Thanks! So would this be considered a level 0 on INES?
More or less. It could be a spurious trip.
The plant shutdown as intended, and the decay heat is being removed as expected.
They will perform a root cause investigation of the trip. Standard operating procedure.
Thanks Astronuc!
Reactor trips are not an unusual occurrence. There are a number of possible things that can cause a spurious trip. E.g. lightning strikes, tin whiskers, who knows.
tin whiskers: hurray for ROHS... on nuclear power plant equipment.
Wouldn't it be a good idea to solder such stuff using good ol 67% tin 33% lead? No whiskers with that, greater metal strength, and this is not ipods that are replaced with new ipods every year.
  • · Replies 19 ·
  • · Replies 36 ·
11K
  • · Replies 34 ·
15K
12K
  • · Replies 205 ·
31K
