How Do You Calculate the Rate of Water Rise in a Varying Depth Pool?
  • Thread starter Thread starter Alethia
    Related rates
The discussion focuses on calculating the rate of water rise in a swimming pool with varying depths. The pool dimensions are 12 meters long, 6 meters wide, 1 meter deep at the shallow end, and 3 meters deep at the deep end. Water is pumped into the pool at a rate of 1/4 cubic feet per minute. To determine the percentage of the pool filled, users are advised to calculate the total volume of the pool and the current volume of water, while for the rate of water level rise, they should derive a function for the height of the water as a function of volume and differentiate it.
  • Understanding of basic geometry, specifically volume calculations for rectangular and triangular shapes.
  • Knowledge of calculus, particularly differentiation and related rates.
  • Familiarity with the concept of rates of change in physics or mathematics.
  • Ability to visualize and interpret geometric shapes and their dimensions.
  • Calculate the total volume of the pool using the formula for a trapezoidal prism.
  • Learn about related rates in calculus to understand how volume changes affect height.
  • Explore the concept of differentiating volume functions to find rates of change.
  • Practice drawing diagrams to visualize problems involving varying dimensions and water levels.
Students studying calculus, particularly those tackling problems involving rates of change and volume calculations, as well as educators looking for practical examples to illustrate these concepts.
Alethia
So I'm doing my homework and I get stuck (again) on this problem:
A swimming pool is 12 meters long, 6 meters wide, 1 meter deep at the shallow end, and 3 meters deep at the deep end. Water is being pumped into the pool at 1/4 cubic feet per minute, and there is 1 meter of water at the deep end.
a) What percent of the pool is filled?
b) At what rate is the water level rising?
Okay what I first did was gather all my given information. That includes all the given dimensions of the pool and dv/dt to be the 1/4 cubic feet per minute. I just need guidance through this problem or where to start... so if anybody is willing to explain to me where to begin... For instance, on part a, do I need another equation for this or is that part of b? ACtually, I don't know what I'm talking about... HELP! :-p
For part a, simply calculate the volume of the pool and calculate the volume of water in the pool. Then get the percentage. (Drawing a picture may help)
For part b, I would write down the function which gives the height of the water level as a function of the volume of water in the pool. Then differentiate that function.
Alethia said:
So I'm doing my homework and I get stuck (again) on this problem:Okay what I first did was gather all my given information. That includes all the given dimensions of the pool and dv/dt to be the 1/4 cubic feet per minute. I just need guidance through this problem or where to start... so if anybody is willing to explain to me where to begin... For instance, on part a, do I need another equation for this or is that part of b? ACtually, I don't know what I'm talking about... HELP! :-p
once you've derived a formula for the volume of the empty space of the pool, i would try to get it into one variable, height. you may need to look at two separate volumes though, the rectangle produced and the triangular shape resulting from the gradiant. from that point you can differentiate with respect to time, since you know the rate the volume is increasing you should be able to figure out the rate that height is increasing. i would suggest drawing out a diagram and digging to remember some geometry.
the first question doesn't make sense to me -- at what point in time is it referring to? if it means initially, i would try looking at the bottom of the pool and calculate the area that's already full. it says that there's 1 meter of water in the deep end.
edit: volume, not area
