New Reply
stable equilibrium
Share Thread Thread Tools
Apr22-11, 06:27 PM   #1
stable equilibrium
I have a object of mass m=5.34Kg. There is a force acting on the object F(x)=(5.0N/m[1][/2])*(x[1][/2])-(1.0N/m)*(x).
1)I need to find the position x0 where the mass is in a condition of stable equilibrium.
2)What is the frequency of oscillation around this position? How would this frequency change if the force was F(x)=(1.0N/m)(x)
Relevant equations:
F(x)=0 in order to get the position of stable equilibrium.
The attempt at a solution
I put the force F(x)=0 and I got x=0 and x=25 but I'm not sure this is the right way to do it.
For part 2 I'm a little confused, could give some hints?
thanks
jon
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Apr22-11, 07:49 PM   #2
Recognitions:
Homework Helper Homework Help
That's the right way to do it, but I can't check your answer because I don't understand your notation. What do m[1][/2] and x[1][/2] mean?
For part 2, think about the differential equation for a harmonic oscillator:
d2s/dt2 + w2s=0
where s represents a small deviation from the equilibrium position. Try taking the second time derivative of x, then rewriting it in the form above, using Taylor series approximations if necessary. w^2 would then give you the frequency.
Apr23-11, 11:37 AM   #3
ok
sorry i was not sure about the way to write that
this is the expression for the force
F(x)=(5.0N/m^1/2)*(x^1/2)-(1.0N/m)x
m=mass
so the first term contains the sqrt of m and the sqrt of x.
I think i made a mistake in the calculation because i didi not plug in the value for the mass. I'm gonna do that again and im gonna try to do part two.
thanks!
bob
Apr23-11, 11:41 AM   #4
stable equilibrium
so i got x=0 and x=133.42
New Reply
Tags
equilibrium, oscillations, physics 1 dimension
Thread Tools
Similar Threads for: stable equilibrium
Thread Forum Replies
Stable or not stable equilibrium Advanced Physics Homework 16
Stable equilibrium question Introductory Physics Homework 2
Second derivative=0; stable/unstable equilibrium? Advanced Physics Homework 2
stable equilibrium problem Introductory Physics Homework 5
Stable Equilibrium II Introductory Physics Homework 1
