Solving a Physics Problem on Position vs Time Graph of Harmonic Motion
The discussion revolves around a physics problem related to the position vs time graph of harmonic motion in a horizontal mass/spring system. The original poster is trying to determine the intervals where the acceleration is greater than zero based on the graph's behavior.
  • Exploratory, Assumption checking
  • The original poster attempts to analyze the graph and relate the intervals of the graph to kinetic energy, questioning the intervals where acceleration is positive. Other participants suggest considering the definition of acceleration as the second derivative and reference textbook resources for further clarification.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the relationship between position, velocity, and acceleration, but no consensus has been reached on the correct intervals for acceleration being greater than zero.
The original poster is working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. The specific choices provided in the question are also under discussion.
dudgey
I have a physics problem that I'm stuck on! Its a position vs time graph of harmonic motion of a horizontal mass/spring system. The question is "where is the acceleration greater than 0?". The graph starts at point A (at the origin), goes to B (above the x axis), down to C (on the x axis), down to D (below the x axis), and up to E (on the x axis).
I thought the answer should be between B&C and D&E because these (I think) would correspond to when the mass was going from a point with no kinetic energy to a point with maximum kinetic energy. This can't be right because the choices are A&B, A&C, C&D, C&E, B&D, both A&B and D&E. What's going on? Thanks :)
The problem might because the question asks greater than 0
Ok, I guess I should just think of it more that the second derivative is acceleration...
Go look in your Textbook there should be a graph comparing
Position vs Time
Velocity vs Time
Acceleration vs Time
