Shouldn't this force have a horizontal component, too?
The forum discussion centers on the tension vector of a rope at joint C, specifically addressing its horizontal and vertical components. The participant argues against the solution manual's assertion that the tension vector only has a vertical component, providing a calculation for the horizontal component using the formula 20sin(20). The discussion highlights the importance of considering both components in tension analysis, leading to the conclusion that the solution manual contains multiple errors, prompting the user to consider authoring a correction manual.
  • Understanding of vector components in physics
  • Familiarity with moment calculations in static equilibrium
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Basic principles of tension in ropes and cables
  • Study the principles of static equilibrium in physics
  • Learn about vector decomposition and its applications in mechanics
  • Explore the law of cosines and law of sines for solving triangles
  • Investigate common errors in solution manuals and how to correct them
Students in physics courses, educators reviewing solution manuals, and anyone involved in mechanics or engineering who seeks to deepen their understanding of tension and vector analysis.
Femme_physics
In the solution manual (which I never trust) the tension vector of the rope that emerges from point A only has a vertical component when calculating the sum of all moments on joint C. I disagree with the solution manual, since this vector also has a horizontal component, and if you calculate its arm it's simply 20sin(20). Sure, small arm and weak vector compared to the vertical one, but still a vector. Am I right?
http://img580.imageshack.us/img580/1845/horiz.jpg
Yup, I think you are right.
If you call the components of tension in the rope Tx and Ty, you have two equations:
1. Take moments about C.
2. The resultant of Tx and Ty acts along the direction of the rope (so you need to work out the angle of the rope to the vertical, from the geometry).
I did using law of cosines than law of sines, it's 62.4 :) Thanks
*snaps finger* another mistake found!
That's practically the 4th mistake, I think.
I'm seriously going to author a correction manual to the solution manual, I will credit physicsforums.com for helping me. I doubt I'll publish it officially, but it will at least be in my college's library and have my professor's stamp of approval.."at least" :)
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 16 ·
14K
