Help with 4017 Circuit for 8V IR Sensor Pulse Counting
  • Thread starter Thread starter dunar21
The discussion focuses on constructing a pulse counting circuit using a 4017 IC, triggered by an 8V output from an IR sensor. The circuit aims to count pulses and activate a small printer motor after reaching a specified count. Users suggest potential issues with noise or multiple firings from the sensor signal, recommending the addition of a 0.1µF capacitor to smooth the input signal. If noise persists, implementing a Schmidt trigger buffer may be necessary to ensure clean signal transitions for the 4017 IC.
  • Understanding of 4017 decade counter IC functionality
  • Basic knowledge of pulse counting circuits
  • Familiarity with IR sensor operation and output characteristics
  • Experience with signal conditioning techniques, including capacitors and Schmidt triggers
  • Research the operation and applications of the 4017 decade counter IC
  • Learn about signal smoothing techniques using capacitors in digital circuits
  • Explore the use of Schmidt trigger buffers for signal conditioning
  • Investigate troubleshooting methods for pulse counting circuits
Electronics hobbyists, circuit designers, and engineers working on pulse counting applications or those needing to interface IR sensors with digital logic components.
dunar21
[URL]http://www.aryanduntley.com/images/4017trial.png[/URL]
If the image doesn't show, it's here:
http://www.aryanduntley.com/images/4017trial.png"
I am trying to piece together a circuit that counts a certain number of pulses and sends out a charge after that number occurred (I need enough power to run a small printer motor) then reset and begin counting again. The picture shows my attempt at a schematic depicting the connections I have in a circuit that is controlled by a 4017 IC. The pulses come from an IR sensor that puts out about 8V. The circuit is not working. I would appreciate any assistance, thanks.
If it is indeed counting something you are probably on the right track. I would bet that there is some kind of noise or multiple firing on the edges of your sensor signal. You could try putting a small capacitor, say .1uf, across the sensor input to see if it smooths stuff out. Going to far in that direction (a way big capacitor) your signal may be too slow such that it remains in the switching range of the 4017 input and causes it to dither. In that case you may need to use a "schmidt trigger" buffer to clean it up.
  • · Replies 58 ·
12K
9K
