Solve Inequality Problem Step by Step
  • Thread starter Thread starter betosasana
    Inequality
The discussion revolves around solving an inequality involving absolute values and a square root expression. The original poster presents a solution that differs from what they believe to be the correct result, prompting a request for step-by-step guidance.
  • Participants discuss solving the inequality over different intervals and combining results. There are questions about the original poster's approach and the handling of restrictions related to absolute values.
Participants are actively engaging with the problem, with some offering to help clarify the original poster's method. There is a recognition of the need for detailed exploration of the steps taken in solving the inequality.
There is mention of specific intervals and restrictions that may affect the solution, particularly regarding the absolute value expressions involved.
betosasana
How can I solve, step by step, this inequality ?
The result I have is [ 1 , (-1 + sqrt33)/2 ]
but the result should be [ 0 , (-1 + sqrt33)/2 ]|x+2|-|x-1|[tex]\geq[/tex][tex]\sqrt{x^2+x+1}[/tex]
thanks for ur help =)
How did you go about solving it? Its a little hard to point out where you went wrong without actually seeing what you did. If i was doing it, i'd solve the inequality separately over three different intervals of x and then conglomerate my three solutions into a final answer.
Please, would you do it and let me know if you got the answer given ?
Coz I took the 3 intervals, but I do not know how to use the restriction |x+2|-|x-1|>=0 on the final results.
I just did it and got [itex]x \in [ 0 , \frac{-1+\sqrt{33}}{2} ][/itex].
If i had to make a guess, i would say that you have solved the inequality incorrectly for the case where -2<x<1
And would it be too much if I ask you to explain it step by step ?
Pleeeeaaaase =P
How about you show me how you did it and ill point out what went wrong? :smile: You were very close to the correct answer, after all.
  • · Replies 32 ·
