| New Reply |
Circuit completion : is it necessary? |
Share Thread | Thread Tools |
| Apr26-11, 09:27 AM | #1 |
It is known that a voltage must be applied around a closed circuit to make current pass through it. So thats why a bulb doesn't glow without connecting both terminals, right?
But, suppose only one terminal of the bulb is attached to a battery and the circuit is closed, the battery still has a higher charge relative to the bulb, so electrons must still go to the bulb, to even out the charge, so why doesn't the bulb glow,even if it is for a small time period?....or does it? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Apr26-11, 09:50 AM | #2 |
| Apr26-11, 10:30 AM | #3 |
Mentor
AlchemistK, I think you may have a misconception about how batteries work. Batteries are electrically neutral, they do not have a "higher charge relative to the bulb". What they have is a potential difference between the terminals. If you touch only one end of the bulb to one of the battery terminals then you have not put the potential difference across the bulb, so no current.
| Apr26-11, 10:43 AM | #4 |
Alright...i see.
So the bulb should light in the above case if instead of a battery, a negatively charged body is used? |
| Apr26-11, 10:54 AM | #5 |
Now you're talking about static electricity... Not sure if enough "equalizing" current would flow to make the bulb flicker. I'm thinking probably not.
| Apr26-11, 11:07 AM | #6 |
Mentor
Assuming that you had a huge amount of charge you might be able to get enough current to make it flicker for a brief moment. Or you could arrange it so that it would arc from the other end of the bulb, in which case you could definitely get a flash, but that is completing the circuit in a sense so it is kind of cheating.
| Apr26-11, 01:09 PM | #7 |
| Apr26-11, 01:17 PM | #8 |
| Apr26-11, 01:54 PM | #9 |
| Apr26-11, 02:52 PM | #10 |
Yes, he is, and yes, you can. It happens quite commonly. I used to have a car that would work well if you kept using it but if you let it sit for a week or two, the battery would drain- there was a short somewhere that was grounding the battery and draining it.
| Apr26-11, 03:03 PM | #11 |
I don't think so.
In your example, one of the terminals of the battery (most likely the negative) was (edit: probably) fastened to the chassis framework of the car to use it as an intentional return path back to the source (the battery). It found it's way back to the battery through the metal parts of the car... It didn't drain itself into the ground through the tires, I assure you. You cannot drain a battery without completing a circuit from the positive terminal to the negative terminal. Connecting a wire from one terminal of your battery to the earth, even if we drove a 10-foot ground rod into the earth and hooked the wire to it, would not drain anything from the battery. (Some kind of failure of the chemical reactions inside the battery could render it useless, but that's a different conversation) |
| Apr26-11, 04:25 PM | #12 |
Recognitions:
Actually you are right, some electrons do go into the buib, but this happens very fast. It would probably take only millionths of a second for the electric field to get into equlibrium and the electrons to stop moving again. You certainly wouldn't see the buib "glow", and in fact it would be very hard to measure what happened with voltages as small as a battery. You can get visible effects from this sort of thing in experiments with static electricity (Google it!) but the voltages involved are thousands of times higher than a typical battery, and even then the amount of power is much to small to make a light bulb glow. |
| Apr26-11, 04:50 PM | #13 |
Isn't everything in some way or another a closed circuit? So one side of the battery could be connected to earth, the other to air, so both of those materials have their conductivities. Not sure what to use for the cross-sectional area or the length of the circuit though to use the formula for resistance: [tex]R=\rho \frac{L}{A} [/tex]. But technically there should be some current and the battery will drain.
What if you bury a battery? If the earth is a really good conductor then should it not drain very fast? |
| Apr26-11, 07:00 PM | #14 |
There is no current flow until there is a complete circuit. Something needs to conduct from the negative to the positive terminal.
Current does not flow out of one terminal of the battery unless it is flowing into the other terminal of the battery. You cannot have one without the other. If you buried a battery in the earth, the dirt between the terminals would very likely conduct enough to form this complete circuit and the battery would drain. If the battery had enough voltage, then the air between the terminals could conduct and we would see an arc that would violently drain the battery. I repeat myself, but I need to say it again... We cannot drain the battery without a complete circuit. It will not happen until the loop from one terminal to the other is complete. We cannot take one wire buried into the ground and connect it to only one terminal of a battery and expect any current to flow. There is no potential difference between a single terminal and the ground. No potential difference means no current flow. |
| Apr26-11, 07:04 PM | #15 |
| Apr26-11, 07:30 PM | #16 |
So if you connect one end of the battery to one terminal of the light bulb, there should be flow of charge from that end of the battery to that end of the terminal, and the opposite charge will build up at the other end of the battery. When the potential between that other end of the battery and the terminal of the light bulb is equal to the voltage of the battery, flow will stop. |
| Apr26-11, 08:07 PM | #17 |
If you're just talking about a couple random metal plates on the ground, I don't think much of anything happened because there were not charges to attract them to each other... there was no circuit made so little or nothing flowed into or out of the plates. The only thing the positive post of that battery is attracted to is the negative post of the same battery. It's not attracted to the ground. It's not attracted to any other battery. It's not attracted to the frame of a car, and it's not attracted to a light bulb. The only thing in the universe that positive post is attracted to is it's own negative post. That's it... nothing else. |
| New Reply |
| Thread Tools | |
Similar Threads for: Circuit completion : is it necessary?
| Simple circuit completion counter | Electrical Engineering | 5 | ||
| Incomplete and completion | Differential Geometry | 2 | ||
| Completion of a metric space | Calculus | 7 | ||
| Completion | Calculus & Beyond Homework | 25 | ||
| Completion problem | Introductory Physics Homework | 7 | ||
