How Does an Ideal Monatomic Gas Cycle Operate?
  • Thread starter Thread starter mlee
    Physics
The discussion focuses on the operation of an ideal monatomic gas cycle involving isothermal expansion, constant volume heat extraction, and adiabatic compression. Key calculations include determining pressures at points b and c using the ideal gas law, finding temperature at point c, and calculating work done, heat exchanged, and entropy changes for each process. The efficiency of the cycle is derived from the work done by the gas relative to heat input, while the overall change in entropy for the complete cycle is assessed through the sum of individual entropy changes.
  • Understanding of the ideal gas law (PV = nRT)
  • Knowledge of thermodynamic processes: isothermal, adiabatic, and constant volume
  • Familiarity with the first law of thermodynamics (ΔU = Q - W)
  • Concept of entropy and its calculation (ΔS = Q/T)
  • Learn about the ideal gas law applications in thermodynamic cycles
  • Study the first law of thermodynamics in detail
  • Explore the concept of efficiency in thermodynamic cycles
  • Investigate entropy changes in various thermodynamic processes
Students and professionals in thermodynamics, mechanical engineers, and anyone studying the principles of gas cycles and energy efficiency.
mlee
Hi people,
Who can help me solve this problem?
One mole of an ideal monatomic gas at STP first undergoes an isothermal expansion so that the volume at point b is 2.5times the volume of point a. Next, the heat is extracted at a constant volume so that the pressure drops. The gas is then compressed adiabatically back to the original state.
Question a:
Calcultate the pressures at point b and point c
Question b:
Determine the temperature at point c
Question c:
Determine the work done, heat input or extracted, and the change in entropy for each process.
Question d:
What is the efficiency of this cycle>?
Question e:
WHat is the change in entropy 'delta s' for one complete cycle a->b->c->a? Explain your reasoning
Question f:
In which part of the cycle does the entropy, S, show the greatest decrease? Explain your reasoning
Many thanxxx
for your help!
Hi there! I am not able to solve the problem for you, but I can provide some tips and steps to help you solve it on your own.
First, let's break down the problem into smaller parts and identify the given information.
Given:
- 1 mole of an ideal monatomic gas
- STP (standard temperature and pressure)
- Isothermal expansion from point a to point b (volume at b = 2.5 x volume at a)
- Constant volume heat extraction causing pressure drop
- Adiabatic compression back to original state
Question a:
To calculate the pressures at point b and c, you can use the ideal gas law: PV = nRT. Since we know the volume and temperature at point a, we can use that to find the pressure at point a. From there, we can use the given information about the volume at point b to find the pressure at point b. And finally, we can use the pressure at point b and the given information about the pressure drop to find the pressure at point c.
Question b:
To determine the temperature at point c, we can use the ideal gas law again. Since we know the pressure and volume at point c, we can solve for the temperature.
Question c:
To determine the work done, heat input or extracted, and change in entropy for each process, we can use the first law of thermodynamics: ΔU = Q - W. We know that the internal energy (U) remains constant for the isothermal and adiabatic processes, so we can set ΔU = 0 for those. For the constant volume heat extraction, we know that no work is done (W = 0), so we can solve for Q. To find the change in entropy, we can use the equation ΔS = Q/T.
Question d:
To calculate the efficiency of the cycle, we can use the equation: efficiency = (work done by the gas)/(heat input). We already know the work done by the gas and the heat input, so we can plug those values into the equation to find the efficiency.
Question e:
To find the change in entropy for one complete cycle, we need to add up the changes in entropy for each process: ΔS = ΔS1 + ΔS2 + ΔS3. We can use the equations we found in question c to calculate the changes in
  • · Replies 33 ·
