Welding Thoughts (Relationship of Current and Arc Temperature)
The discussion focuses on the relationship between welding arc temperature and the current (amps) flowing through the welding process. Common arc temperatures range from 3000 to 8000 degrees Celsius, with factors such as electrode properties, arc length, and polarity influencing the resultant temperature. The participant suggests using formulas like Power=I^2*R and Q=mcdt to understand these relationships, while noting that the temperature at the welding tip is less dependent on current than the temperature further away. A referenced paper provides additional insights into calculating temperatures at various points within the weld.
  • Understanding of welding principles and techniques
  • Familiarity with electrical concepts, specifically Ohm's Law
  • Knowledge of material properties, particularly electrical resistivity
  • Basic grasp of thermodynamics related to heat transfer
  • Research the effects of electrode diameter on welding arc temperature
  • Study the impact of arc length on heat distribution in welding
  • Explore the relationship between welding polarity and heat generation
  • Examine the referenced paper on temperature calculations in welding
Welders, welding engineers, and materials scientists interested in optimizing welding processes and understanding the thermal dynamics involved in arc welding.
Grayfox
Common Temperature ranges from a welding arc can range from 3000-8000 Degrees Celsius. I would like to know the direct relationship of a resultant arc temperature based on the amount of current (amps) flowing. Let's say common steel for the base metal (Electrical Resistivity: 1.74e-005 ohm-cm). One can adjust the amps from a welder to say 125, but I'm not sure how other variables such as properties of the electrode (mig wire resistivity, diameter), length of the arc, or even reverse polarity (we'll assume straight polarity) affect this value. My guess is that if the electrode (welding gun wire) is +, more heat is generated at the electrode, and if the base metal is +, a larger portion of the energy is distributed to the base metal. Of course we'll neglect any heat transfer with the shielding gas or ambient air. Getting past all that, would we apply something like Power=I^2*R or Q=mcdt?
The temperature at the tip is pretty independent of the current. But it is sensitive to the surrounding gas, and the rod composition and shape.
But the temperature away from the tip does depend on current, and geometry, air flow, and other factors.
The following paper, talks about ways to consider all those things to calculate temperatures at different point within the weld.
https://www.sciencedirect.com/science/article/abs/pii/S135943111931350X
11K
11K
  • Sticky
  • · Replies 705 ·
24
125K
11K
28K
12K
